Question about CyberPower OfficePower 625AVR UPS System
Wiring fault light on. What it is the problem?
  • 38 Answers
Most likely the outlet the unit is plugged into is not grounded, needs to be grounded for it to work properly
Posted on Sep 11, 2010
. Airbag light stays on
A common problem across the whole range of cars. They could be a genuine fault, a faulty sensor or a wiring problem. Best thing to do is get the fault diagnosed with a reader to determine the actual fault or faults. Ask around as a friend of a friend may have one or contact a local mechanic.
Often the airbag light is just a bad wire under the seat as the seat is moved back and forth whilst adjusting it. Wiggle the wires and see if the fault can be reset with the OBD reader mentioned earlier.
Oct 16, 2015 | 1998 Chrysler Concorde
Is it possible to have an abs fault with out light on dash ? The brake warning light is on but the garage is saying it's an abs fault ? Wire snapped at the end of brake pad ?
Wire snapped would be to the wheel speed sensor. Usually, a faulty wheel speed sensor will trigger the ABS light, A broken wire? Not sure, but why not fix it?
Jul 22, 2015 | Cars & Trucks
Mazda 3 rear light fault
you have a bad ground somewhere in the wiring from the switches to the rear. Get urself a multimeter and start checking for shorts or bad grounds.
Dec 14, 2013 | 2005 Mazda 3
Fuse for tail lights keeps blowing
You have a serious short circuit in the wiring to the tail lights. Fuses protect the wiring in your vehicle from catching fire.
You need to trace the tail light wiring from the fuse box to the tail lights to locate the fault/short circuit.
A wiring diagram can help as it shows the colour code of the wires to the tail lights.
This problem can be difficult to trace and you most likely need an auto electrician to fix this problem. It could mean installing a new wire to the tail lights as a quicker fix and bypass the fault..
Apr 19, 2013 | 1993 Nissan Quest
I have a 2005 Kawasaki z750s. Both headlights went out at the same time. My tail lights and all dash lights work. Is it a fuse or wiring?!
Possible water damage to head light relay in the fuse box under the seat or the stator which controls the head light relay. Get a auto electrician to do an trace check on the wiring & connections to rule out all other faults. If the lights cut out after an heavy bump and come back on after a set time, the fault could be the relay or stator. Have the auto electrician resolder the relay connections in the fuse box (about 40 connections), also have an 12v LED warning light fitted to the stator connections with enough wiring so the LED can be mounted on the handle bar. If the LED cuts out the stator is at fault(very costly), if the LED stays on the head light relay is at fault. Also better waterproof the standard fuse box , the case is not that waterproofed (easy done with insulation tape). Hope this helps.
Dec 11, 2011 | 2008 kawasaki Z750
Hi i have an 1986 toyota 4runner the dash lights and running lights stopped working... fuse is blown and checked wires in the tail lights, marker lights and behind the dash with no luck... is there a...
The tail and marker lights and Instrument lights are on the same circuit so both will go out if the fuse for this circuit blows. If fuse continues to fail, check the tail light or marker globes, including the globes for the number plate, for a globe that may have an internal short causing the fault and replace as necessary. As you have already checked the wiring near the light fittings for any chafed wires that could be shorting to the body causing the fault, then a closer inspection of the wires inside all the light assemblies for any shorts may be needed.
It could also be that the instrument dimmer control has failed and is causing the fault. The electronic bits inside the dimmer control for these lights sometimes go faulty. Try disconnecting the connecting plug on the rear of the dimmer control and checking if fuse still blows. If fuse continues to fail, then the fault in the tail and marker lights circuit.
Remove all the tail, number plate and running light globes from the light assemblies and leave the instrument dimmer control disconnected and check if fuse still blows.
Disconnect the plug near each of the light assemblies to see if any of the individual assemblies is causing the fault. With all light assemblies disconnected and fuse continues to fail, then the fault must be in the main wiring loom some where.
If you have a Multimeter, it could be used to determine which light assembly has a fault between the lamp supply and earth connection.
Feb 25, 2011 | 1987 Toyota 4Runner
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
What does the ambere (yellow) light on the breaker mean when you turn it on or it trips out and you reset it
If the Siemens 20Amp 1-pole arc-fault circuit breaker is wired correctly and there are no problems with the circuit that it is protecting, when first turning it to the ON position, the amber light will come on then go out after about 10 seconds or so.
If the breaker is wired incorrectly or there is a fault in the circuit the amber light will stay on.
Nov 07, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Wireing Fault Light is On
check the phase rotation of ups input, if it is a 3 phase input
Oct 14, 2009 | CyberPower 525SL (CPS525SL) UPS System
CyberPower OfficePower 625AVR UPS System Logo
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
