Question about Dishwashers
Where is the filter to clean in my dishwasher - Kenmore model 17532201? Do you know where I can find the manual for it? No, it's not anywhere in my house : )
  • amybperry1 Sep 11, 2010
    Thanks - that was the manual. But I'm stil confused about the filter - at the base of what and is cleaning it necessary. I think any filter would need to be cleaned from time to time. The manual doesn't mention anything about it.
    Thanks - that was the manual for my model. But I'm still confused about the filter. You said it was at the base - at the base of what and is cleaning it necessary? I think that any filter would need to be cleaned from time to time. The manual doesn't mention anything about it.
  • Dishwashers Master
  • 2,605 Answers
Hello, Welcome to FixYa. The pump filter in your dishwasher is ( in theory anyway ) self-cleaning. The pump well/sump does get quite dirty though and yes, can be difficult to remove. I find removing the top rack to be the best place to start. However I also find sometimes visual "how to" instructions are better than explanations, therefor I`ve attached a video for you to check out. http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1 ( not sure if the "link" works sending via my iphone so you may have to copy & paste ) This should help you get to the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well. The key is to get in there and clean it all out, This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air. When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher vinegar bath. Unfortunately I don't have a manual though. You could try "searspartsdirect.com" they may have one available for purchase. Let me know how you make out and what you find. Good luck. Regards, Macmarkus :)
Posted on Sep 11, 2010
  • 3,247 Answers
The manual can be downloaded from this site. I hope it is the one for your model.
The filter is usally at the base. Hope this helps.
  • Sam Sep 12, 2010
    Sorry, I did not realise you had responded a while ago.
    Your dishwasher uses an intelligent cleaning method with a chopper to remove and flush the waste.
    However, the filter is inside the wash assembly in the base. Best to check out this diagram of the pump and motor. The filter is attached to the chopper assembly which is item 6.
    You will have to open the pump assembly to get to the chopper for cleaning.
    So unless you are getting any problem this may not need to be touched.
    Hope this helps with your query.
  • Sam Sep 13, 2010
    It is pity you already got a refund from fixya when I provided you the manual you needed and alos worked on giving you details of the location of the filter.
Black rubber pieces falling out of Kenmore Model 13869K602 ?
A washer or grommet is degrading... Start checking the easy stuff: hoses, arms, filters first but it may be anywhere inside the machine. Good luck. A call to manufacturer might give you some places that most commonly see this problem.
Apr 28, 2014 | Kenmore 24 in. 16462 / 16464 / 16469...
Where can I find an online trouble shooting guide or owners manual for my Kenmore dishwasher 36314489100? It will not drain.
Hi
You can download the manual from this link--
Kenmore dishwasher 36314489100 User Manual
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 20, 2011 | Kenmore Dishwashers
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Dishwashers Logo
397 people viewed this question
Top Dishwashers Experts
Owen Barnes
