Question about Miele CVA 4062 Stainless Steel
Hello my miele cva 4062 when i turn it on it says error 81
  • mison88 Sep 12, 2010
    Were are the conections located in the machine? when i Open the dore there aré no wires pelase tell me how do i check the conections.
  • 944 Answers
F
ault error 81means-Internal circuit board problem.This error will be cause due to short circuit in the board or the wiring connections internally loose.Use multi-meter to check you are reading volts on the board.If there is no change in the multi-meter then circuit needs service.Check for loose wiring connection
Click here to download the manual.Use this for more help in maintenance.
Note:Usually this problem arises because of Not using the
Switch On/Off button.You would have directly used the main switch with out using the Miele CVA On/Off button.This causes the board to experience sudden increase or decrease in voltage
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 12, 2010
    The place where you can see on/of led behind it is the board present.
Miele cva 4070 fault 81. What is this?
F81 is a steam heater fault - either the fuse or the steam heater itself are faulty, however if in fact you don't use the steam function - you can disable this in the setup menu
Oct 15, 2017 | Miele Coffee Makers & Espresso Machines
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
Brew unit stuck miele 4062
This has happened to me many times. Just turn off the main power, turn it back on open the door and close it so the brew unit repositions itself. The unit should come out easily now.
Jul 07, 2014 | Miele CVA 4062 Stainless Steel
I need a replacement milk flask for a miele cva4062
These are very hard to come by! You will want to check with your local Miele dealer for part 7271552. No one makes suitable replacement parts and replacing this will run you about $300-400 + shipping (likely come from Europe). I have yet to find this part readily available in North America.
Suitable for CVA506x Miele Accessories Miele UK
Feb 26, 2014 | Miele CVA 4062 Stainless Steel
Miele coffee
This machine needs an overhaul.
the boiler is leaking along with several o'rings.
Dec 21, 2013 | Miele Germany CVA 4062 Whole Bean 500g...
I'm trying to find a place tp order a replacement part for my 4062. I just need the small rubber gasket that fits over the tip of the main line that inserts into the machine when you close the door....
if you still have your parts kit that came with the machine, there is a spare o ring included. It had a small tube of silicone grease, a pipe cleaner, cleaning and descaling tablets etc in a cardboard box. you should also have a spare air orifice for the milk frother. if you cant find it, just call 800 843 7231, press 0 and ask for parts. tell them what you need and they will mail it to you.
Aug 22, 2011 | Miele CVA 4062 Stainless Steel
I have a Meile CVA 615 coffee maker that has a problem. It is producing lots of liquid in the collection tray on the front of the machine. It is also taking longer to make a cup of coffee and...
Hi
It's time to de-scale your machine, please check the bellow link to read the manual and check how to de-scale your appliance:-
https://www.ajmadison.com/ajmadison/itemdocs/CVA615_us.pdf
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 17, 2011 | Miele Coffee System
Miele CVA 4062 Stainless Steel Logo
376 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
