Question about Princeton Digital VL1514 Monitor
My VL2018W LCD monitor shows blurred words and often has a blank screen - when I reboot and turn the monitor off and then on sometimes the words become clear again - is it dying?
  • 11,361 Answers
You may have dying power supply due to bad caps as shown here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 11, 2010
Cannot find driver for VL2018W Monitor was working but then went blank Is it a goner or might the right driver help
Driver will not cause the screen to go black, look for bad caps inside, it is very common problem.
See Princeton VL2018 album.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 22, 2010 | Princeton Digital VL2018W Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
My princeton VL2018W will flash the screen when first powered on but goes blank after. With repeated unpluging, the display used to stay, but no luck
floresa57, After lcd panel "flashes" is the lcd panel "black" or is it both "black" and "blank" when you perform the flashlight test that every LCD owner should know how to do and interpret the results? Do you have warranty? If no, then read more responses in my FIXYA profile for clues on what YOU will or what YOU won't do to fix your BLACK SCREEN monitor!!! Floresa57, the basic principles of design and operation of your Princeton VL2018W are same as all other brands of Fluorescent backlit LCD monitors!!! It can be fixed. READ, READ, before you do anything. Understand the reason WHY your monitor is now black and lifeless. Follow all the LINKS to other web sites so you will be informed and less likely to be overcharged on a repair job that should have cost less than $50. Good luck Floresa57. Rate this on FIXYA if it was of some use to you. 12fixlouie
Jan 05, 2010 | Princeton Digital VL2018W Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
Aug 03, 2009 | Princeton Digital VL2018W Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor does not turn on automatic
change your power cable.
also check your power suply and earthing.
Nov 19, 2008 | Princeton Digital VL2018W Monitor
Princeton Digital VL1514 Monitor Logo
69 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
