Question about Dryers
Dryer wont ignite heat ect... - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer will not heat. Just put in a new igniter but still wont heat
3 rules of heat, Fuel , Air , Ignition
Gas Valve turned on?
Is the ignitor either glowing or sparking pending on the type?
Aug 22, 2013 | Roper 29 Gas Dryer
Amana gas dryer, just stopped heating. What can we look at to see if its anything worth fixing? All we have done is take it apart.
a pretty common thing wrong when it doesn't heat is the gas valve coils...but if the coils are bad typically it will heat at the beginning of the cycle but after it has been a while
i have included a tip about the gas valve coils http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
but a little seeing what it does or does not do would be more helpful in diagnosing the problem..such as does the igniter come on and go off but no flame,does the igniter not glow ect ect....
Aug 25, 2011 | Amana Dryers
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Is ther a pilot light my roper rgs7648kq2 dryer is not heating up what could the problem be
All modern gas dryers use a hot surface igniton system(very old dryers had pilots). There could be a problem with the igniter,gas valve, ect. If you remove the bottom cover panel or inspection cap you can check to see if the hot surface igniter starts to glow when dryer is intially started. Just because the igniter does not glow does not mean that the igniter is the problem. There are two gas valves that work in conjunction with the ignition system as a safety(one could be defective). Also make sure that the gas connector at the back of the dryer is not restricted(kinked) and the gas line valve did not get shut off some how.
Sep 05, 2009 | Roper RGS7646KQ Gas Dryer
My Neptune dryer mdg5500awgg wont heat up. Any suggestions?
I am providing some links courtesy of www.repairclinic.com that will assist you in the diagnose/repair of your dryer.
Firstly, ascertain that you have made a positive heat selection on the control panel switch, then proceed onward.
Parts breakdown/disassembly procedures:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
1. Gas Valve Coils image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3479&PartID=3479
2. Ignitor image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3018&PartID=3018
3. Thermal Fuse image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di516650&PartID=516650
Aug 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
Turns on but wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jul 13, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
Dryer wont heat up
The most likely cause is a burnt out igniter. (part #
WE4X739) The igniter is a pencil shaped curly wire thing with a two pin disconnect located between the gas valve outlet and the burner box.
Aug 28, 2008 | GE DBXR463GB Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
