Question about Epson Office Equipment & Supplies
Epson stylus pro 9900 light light black clogged
  • rhodopsin1 Sep 11, 2010
    The printer is a 1 year-old epson stylus pro 9900 purchased 1 1/2 years ago. It has printed approximately 3500 prints without any problems whatsoever until about 3 weeks ago. The problem occurs with the nozzle test prints. The light light black section is missing approximately half of the test lines in these prints. Paired cleaning and a power cleaning have failed to correct the problem. I also tried applying water to the cap assembly and allowed the printer to sit overnight without any success. The problem began abruply after I changed the ink for the light light black channel.
  • Epson Master
  • 11,800 Answers
Since the problem appeared after you changed the ink then the ink was either the wrong composition - a bad batch - or it was incompatible with the old one and it reacted chemically with it and clogged the head. There isn't very much left you can do now - you should remove the printing head and let it soak over night in isopropylic alcohol, it's a powerful diluent, then wipe it with a paper towel and resoak it until the towel comes out clean.Then remove the present cartridge and buy a new one, identical to the first. Finally run some more deep cleaning cycles.
If even that doesn't unclog it then the head is gone, you will need a new one.
Posted on Sep 11, 2010
    President:
  • 2,777 Answers
I am confused by your question here... do you have a light / error message lighting up on the printer? What exactly is clogged? I can definitely help you but need more info.
Thanks
Tim
Epson Stylus Pro 4900 with error code 1433. What does this mean?
Error 1433 means "IS Unit position sensor error".
unfortunately this issue is a major one and will need to be repaired by an Epson technician.
Sep 06, 2014 | Epson Stylus Pro UltraChrome HDR 4900 Ink...
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Print head go left and right non stop when the command for print is given - but does not print anything even when ask to do a nozzle check - the printhead goes al the way left and right again and again...
When was the last time the machine worked, please? What you describe sounds like clogged or dry print heads.
What happens if you try cleaning the heads not the standard once, but at least four time in a row without doing anything else in between, please? Don't try a test, don't switch off; just run the cleaning routine at least four times in straight row. (Sorry that might use a lot of ink)
Feb 04, 2014 | Epson Stylus Pro 9900 - 44" large-format -...
How to removed error code 0002 on epson stylus 7800
problem with epson stylus pro 7880
how to removed error code A0000170
Oct 02, 2013 | Epson Stylus Pro 7400/7800/9400/9800 Matte...
Printer reports out of Light Magenta ink even after new cartridge installed.
discovered recently that printer cartridges have a use by date on them, and that if you use it the printer will not recognise it, only answer is to insert a new one, or ignore the printer ( l have a by-pass function on mine so still use it until l am ready to replace the offending cartridge
Jan 30, 2013 | Epson Stylus Pro 9900 - 44" large-format -...
EPSON 11800 Having an Error code: 1A39
hi the same for me 1A39 on a 9900, i check everything nothing else to do than to change the print head, in fact it's an active signal send by the head it self.... mean that it's defect ..........good luck ! good forum for help on epson printers : http://www.luminous-landscape.com/forum/index.php
Jun 15, 2012 | Epson Stylus Pro 11880 InkJet Plotter...
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Epson stylus pro 4800 black ink problem
When you put the printhead back into the machine, did you seat the dampers correctly?
Aug 07, 2008 | Epson Stylus Pro 4800 InkJet Printer
560 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
