Question about Intermatic EI210 Electronic Auto Shutoff Timers
I have an ST01 timer that I want to place in a three way circuit that appears to be different than that shown in the directions. My circuit has power (black/white/ground) coming into switch 1 with a three wire setup (red/black/white/ground) going to switch 2 that then goes to the lights (black/white/ground). I would like to replace the second three way switch with the ST01 but I can't figure out how to replace it. All of the combinations I've tried don't make switching happen from both switch positions. Is there a diagram for the way my wiring circuit is set up? Thanks, Steve
  • Bob
    Bob Sep 11, 2010
    Which do you have? The ST01 or the E1210? The E1210 can only be used to replace a single switch. You need to use an Intermatic EJ500C or similar.
  • 565 Answers
One caveat of most In-Wall electronic switches/timers is that the device _must_ be installed at the switch box that has the power, in your case switch #1. In order to install it at switch #2, in your case, you need an extra wire between the switches (to carry the HOT wire), and unfortunately, the bare ground(ing) wire is not permitted to be used to carry current per National Electric Code (NEC).
In your case the wiring for the ST01 is as follows:
Switch box #1: Connect the incoming White wire to the White wire in the 3-wire cable that goes to switch box #2. Connect the incoming (Black) HOT wire to the Black wire on the switch/timer. Connect the Red wire in the 3-wire cable to the Red wire on the switch/timer. Connect the Black wire in the 3-wire cable to the blue wire on the switch/timer. Connect the green wire on the switch/timer to the 2 bare ground(ing) wires. If you have a metal box this connection should also have a pigtail that connects to the box with a green ground screw.
Switch box #2: Remove all of the existing wires from the 3-way switch. The three-way switch will have 2 screws the same color (usually black) and 1 screw (usually brass). For this scenario, one of the black screws will _not_ be used.
Connect the Black wire in the 3-wire cable coming from switch #1, the Black wire going to the lights, and a short Black pigtail together under one wirenut. The pigtail is then connected to the brass screw on the 3-way switch. The Red wire in the 3-wire cable coming from switch #1 is connected to one of the 2 black screws on the 3-way switch (pick one).
In effect you are installing a single switch at switch box #2. In fact, you can use a regular single pole switch if you want too.
To finish, connect the White wire in the 3-wire cable coming from switch #1 to the White wire going to the lights.
Grounding is the same as switch #1 except you'll need a pigtail to connect to the green screw on the 3-way switch.
That's it. You may want to check the battery compartment in the switch/timer, as sometimes they put in a pullout plastic tab to keep it from being energized until needed.
Now, the E1210 is a different animal, and can only be used to replace a single pole switch. You could use it by basically passing the power through to switch box #2 from switch box #1 and then cover switch box #1 with a blank plate. The ST01 could be used that way too, in which case the black on the device connects to the hot, the blue to the lights, and the red on the device is not used, nor will the Red wire in the 3-wire cable between the switch boxes be used.
Posted on Sep 12, 2010
I have a utilitech in wall timer model 0192773 which is about 2/12 yrs old. It has power but will not automatically turn on. I called the company and was told that it has a non-replaceable battery which...
The battery is a capacitor back-up charge holder on the circuit board... in case power goes out the memories are held for a period of time.
Just because somebody answers the phone at a company doesn't mean they weren't selling popcorn the week before.
-Buy same-similar timer at Lowes and return defect in new package.
-Buy timer with battery and 5-year warranty.
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Feb 20, 2015 | Hardware & Accessories
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
Gene
Dec 05, 2014 | Hardware & Accessories
When hitting the next/on/off button, it dims the lights vice turning them off???
The EJ500 is rated for incandescent (resistive) bulbs only, and not LED CFL etc.
Max distance between light and timer is 100 feet and wire cannot be underground.
Replace with ST01 timer, or Ei600 timer... these timers are rated for any load (resistive or inductive), and are programmable or dawn-dusk... 7 day... single-pole or 3-way
Gene
Nov 12, 2014 | Intermatic Inc. EJ500C Digital Wall Switch...
Can Woods model 59007 be used in house without
http://waterheatertimer.org/How-to-wire-timers.html
Ground wire is not essential, but neutral wire is
yes the red wire has to be connected to black wire that goes to load
If all you have are two black wires, then use battery operated timer like ST01 or Ei600
Gene
Sep 01, 2014 | Hardware & Accessories
Intermatic ej500
Florescent bulbs are not discontinued.
Incandescent bulbs are being phased out so you can save electricity to run your great-big 600 watt TV....
http://waterheatertimer.org/What-is-3-phase-electric.html
Or, in a few years from now, you can support the economy and buy another timer:
Buy new EJ600... same keypad as EJ500, except different wiring since neutral wire required
or
Buy ST01 or Ei600 timer: identical wiring to EJ500, same dawn-dusk or programmable options, higher load rating, works with any voltage, CFL, LED etc, different programming steps, different battery.
Ej500 has 1 year wareanty
ST01 has 1 year warranty
Ei600 has 5 year warranty
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej600
Gene h
Jan 20, 2014 | Hardware & Accessories
We have three Intermatic self-adjusting wall switch timers - all are Model ST01 series. All we are trying to do for each one is to set the on and off time. We do not want to use the Dusk/Dawn feature -...
Open following link for ez instructions with illustrations.
You still have to read everything carefully, but illustrations show what to look for.
http://waterheatertimer.org/ST01C-program.html
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Sep 13, 2011 | RTO Intermatic Inc St01c Digital Wall...
How do I replace batteries in the ST01 series timer
The Intermatic ST01 uses a CR2 3 Volt-DC battery to operate the "click-clack" ON - OFF function of the timer.
In order to change the battery, simply pull down the flap just below small display screen. This is the manual switch that you can push to turn the timer on and off.
Just use your fingernail at the top of the door flap and pull down, it will open up and reveal another small tab. This is the battery holder/tray.
To open this, either use your fingernail or a small flat bladed screwdriver at the top to slide out the battery holder tray.
If you remjove and replace the battery within 30 seconds or less, you won't have to reprogram the time/day/date/year. Otherwise taking longer you'll have to reset the time and date feature of the timer.
Don't worry, the timer remembers your program ON - OFF cycles regardless of whether the battery is in the timer or not.
Hope you find this Very Helpful and best regards!
Aug 24, 2009 | Intermatic Hardware & Accessories
Intermatic EI210 Electronic Auto Shutoff Timers Logo
252 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
