Question about Eureka Capture Upright Vacuum Vacuum
What does it mean when the check brushroller light comes on
  • muitt7 Sep 12, 2010
    thx jim, theres no hair around brush, new vac, used once, will try ur solution, thanks again pam
  • 1,040 Answers
Thank you for accepting my bid!
When the brush roller light comes on, this indicates that it is stuck. However, it could be three other possibilities.
If the brush roller is freely turning, then:
(1.) Check for hair around the belt area of brush roller. Hair could be causing the belt to slip.
(2.) The belt is stretched out. This is common after much use.
(3.) The brush roller bristles are no longer touching the floor, (wore out). You will need to purchase a new brush roller.
I hope this solves your problem!
Jim P.
Posted on Sep 11, 2010
  • Jim Parker
    Jim Parker Sep 16, 2010
    Thanks for the rating!
    If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:
    "Tools- Building
Belt won't stay on floor tool
The most common reason is the belt but since you replaced that it may be the brushroll. Check to insure it will spin freely. The motor shaft and brushroll must be parallel to each other. If the motor is not mounted securely it could cause the belt to come off. Turn the brushroll slowly by hand and carefully observe to see if you can see what could be causing it to come off.
Mar 13, 2017 | Kenmore Vacuums
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
MY DYSON DCO7 DOES NOT PICK UP FUZZ AND HAIR FROM CARPETS
check if brushroll still spins when it comes in contact with the carpet. Your belts could be so stretched that its just slipping on the brushroll.
Jan 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
Jan 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
When switched on the brushes dont go round and it wont **** up but when i use the handle to clean theres suction there does this model have a belt?
it has a brushroll and transmission i think. turn the top screw and rotate til the end of the nozzle comes off. then pull the brushroll out from each side see if the shafts on the transmission are rotating and also check the inside of the brushrolls for wear and stripping where the shaft is inserted. could also very possibly be the brushroll switch on the top. there is also a small switch on that turns the brushroll on when the ball cradle retracts back. those sometimes go bad. Ive also encountered where the wires that run inside the ball housing snap. they are very low gauge wires. you will need a T10, T15, and a T20 to get into the upper and lower switch assemblies
Jan 02, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Cant rember how to replace the belt on the power head
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off of the Kirby's driveshaft but on the "hook" inside the power nozzle) 2)Remove the power head from the front of the machine. Now that it is off the Kirby, you can turn the square belt lifter until the green arrows line up. (Belt on, which means on the driveshaft on the front of the Kirby when the power nozzle is on the Kirby which makes the brushes spin. Now that the power nozzle is off of the Kirby, the belt isn't actually resting on anything but the green arrows will still point to belt ON ) This removes the belt from the "hook" so that it can be slipped off the brush roll. 3)Turn the power nozzle upside down and release the two clips that hold the metal baseplate on and remove the baseplate. 4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. 5)Look at the ends of the brushroll. The brushroll has three height settings..you should see notches AND NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong. Also, one end cap of the brushroll is larger than the other and will only fit onto the larger notch in the power nozzle. 6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage. 7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place. 8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 without suction
you probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Aug 20, 2008 | Kirby G6 Bagged Upright Vacuum
Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Eureka Capture Upright Vacuum Vacuum Logo
88 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
