Question about Blenders
Waring blender motor makes a noise, and a burning smell when running.
    Sergeant:
    Novelist:
  • 193 Answers
The motor is "burning out" It is not economically feasible to repair it. It will soon stop completely and could possibly overheat the cord or base of the machine. I would recommend throwing it away. If you want to use it until the last second, always unplug it when not is use and do not leave it unattended while running. I wish I could give you more hope than that, but there is no way to repair it.
Posted on Sep 11, 2010
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
Waring blender switch wiring
most blenders throttle the power by using different taps inside the motor winding themselfs ., the switch just selects what tap to use and applies power to that winding , just three windings can produce multi speeds if used in combinations sorry no easy fix for switchs other than to make sure theres no food down inside them , i use a good electrical contact spray (CRC) down in them to make sure
May 01, 2014 | Waring Blenders
Need picture waring mbb518 blender motor
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
Nov 24, 2013 | Waring MBB518 2Speed Blender
Waring 34BL87 blender is loud and gives off a strong burning smell whenever used. Burning smell apparent since first day of use and getting worse with age. Is this odor normal or does it indicate the...
no, that is not normal. it could be from a loose or misallignment rotor or shafting. if its under warranty you should return it from the store...
Jun 17, 2011 | Waring TG15 Blender
My cb15 blender is making noise and I think bearing are worn out
most of the time they are a bronze bushing and needs to be cleaned and use silicone grease as an lube. check the motor bearing as well
Mar 19, 2010 | Waring CB15 Work Top Blender
Waring pro wpb blender emit burning smoke and smell when i was blending ...
Obviously the motor winding is burned out. it needs to be rewound. This is can be done only by repair men who regularly wind motors.
All blenders have one thing in common. They draw more than rated current when running slow. If u continued using it inspite of noticing low speed then the it results in burnt motor winding as is the case now.
Also the blenders should not be run on no load, which will cause meahanical damage to fan and bearings.
Oct 16, 2009 | Waring WPB 01 / 04 / 05 / 09 Professional...
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Blenders Logo
400 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
