Question about Garden
Can I get manuel for a Mantis 2 cycle tiller.? spltrail@windstream.net Have a bad gear and need scymatics to fix.
    President:
  • 1,545 Answers
You can check for one here:
http://www.manualsonline.com/
Posted on Sep 11, 2010
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
Tines bent
I would call mantis - the tines are covered by a lifetime warranty, and they should send you replacements for just S&H... not a bad price to pay for new tines.
Jan 28, 2013 | Mantis 2-Cycle Tiller
I need an owner's manual for Mantis mini tiller
Try www.mantis.com. You should be able to find the manual for download or request one from Mantis.
May 22, 2011 | Mantis 2-Cycle Tiller
I had my 2 cycle tiller at a shop and he told me
Mantis Product Owners Information
spacer.gif arrow_red.gif Submit your Question spacer.gif Please Select a Category Below arrow_green.gif Mantis Tiller/Cultivator Gas Tiller FAQ (12) arrow_green.gif Mantis SprayPartner and SprayMate FAQ (7) arrow_green.gif Mantis Blower/Shredder/Vac Service FAQ (3) arrow_green.gif Mantis ComposT-Twin FAQ (10) arrow_green.gif Mantis Edger FAQ (7) PARTS
If you need parts, or wish to return a product, please call our Customer Service Department at 1.800.366.6268
Hours are Monday through Friday 8:00 AM - 5:30 PM Eastern time.
Jun 07, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
4 stoke mantis tiller, loud noise not in engine, maybe the clutch
If you can get to the dry bushings, DuraLube pump lube will fix your problem. It is available at most automotive stores and departments for $8 -10. I've used it in areas where I had to lube every 10-20 working hours. Now i can go 200-300 working hours. You can also add 2 or 3 ounces to your crankcase oil.
Jan 29, 2009 | Mantis 4-Cycle Tiller
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
