Question about Electrical Supplies
Can i install electric starter on 10hp briggs & stratton ?\r\n Thanks !
    President:
  • 1,388 Answers
Easy to check if your engine was designed for additon of starter. Starter motor is mounted at rear of engine to gain access or flywheel. The block would need to have mounting holes already drilled into block and the flywheel will need to have ring gear. There should be a removable plate on fan cover (or cutout) to allow starter to enter flywheel. If your block has mounting holes but not the geared flywheel, you could try to find a dead motor with good starter parts at small engine shop. Good luck
Posted on Sep 11, 2010
Not able to find listing for Briggs Stratton 126907 1473
MAYBE this is the right number ? 12S907 1473 B1 by a little suggestion
http://www.partstree.com/parts/briggs-and-stratton/engines-vertical-engine-with-electric-starter/12s907-1473-b1-briggs-stratton-engine-electric-starter/air-cleaner/
Briggs and Stratton 12S907 1473 B1 Briggs Stratton Engine Electric Starter...
Oct 21, 2016 | Briggs Measuring Tools & Sensors
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Jul 21, 2010 | Briggs & Stratton Garden
Replace starter on my 20 hp briggs
check that battery is installed properly,i once got a bad batterie that was wired reverse.and the starter ran in reverse.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Electrical Supplies Logo
161 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
