Question about Sony Cyber-shot DSC-W55 Digital Camera
My camera says "No memory space on Memory Stick" but I am not able to view them on the camera. I am abal eo to view internal memory photos. I know i have pictures on the memory stick as i can see them on other devices. Why won't my camera allow me to view them?
  • 1,606 Answers
Usually when you get this the card is the problem. Most of the time the actual cause will be just from it being in use when the device was shut down so it didn't finish properly. There is a little table called a file allocation table or FAT table that tells the device what and where the files are. The problem is that it is easily corrupted. It can happen by taking a bunch of pictures then shutting off the camera quick or yanking out the card. The cards do fail but not that often. If it is a card problem then this will happen more and more as the card gets worse.
The fix is just copy your pictures off the disk. Reformat the disk either in the camera or pc and that will fix it. If the reformat doesn't fix it then you may need to replace it.
Posted on Sep 11, 2010
Does this camera have internal memory? Cannon EOS 600D Rebel T3i
It has some internal memory, for keeping track of things like the date and time. It does NOT have internal memory for storing photos.
May 17, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
NO space on internal memory
Hi. Actually you justneed to delete or transfer some pictures on the internal memory to your memory stick or you could remove first the memory stick and plugin you digital camera to your computer and copy all the pictures or videos on the internal memory of your digital camera.
Jun 04, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
Jan 11, 2010 | Olympus FE-280 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
Is there a way to transfer photos saved in internal memory to the memory card?
Try by removing the memory stick and then attaching the camera to computer with USB cable. Switch on camera. It should open up a dialogue box in Windows XP (or similar OS). Select 'open folder to view file' or open Windows Explorer and open camera folder (probably displayed as new drive E: or like that in My Computer) . You may also check whether there is an option of selecting "camera as mass storage device" in settings menu of camera. If yes then select this before connecting. If you have no means of attaching the camera to the computer, place an empty memory stick into the camera. In review mode, a message indicates there is no data, but there is in the internal memory. While still in review mode, press the menu button and go the the "Setup" section, the last option. Now, scroll down to the "Memory Stick Tool" section. From there, highlight the "Copy" choice at the bottom, and select the OK option to proceed. You will get a message: "All data in internal memory will be copied." Press OK, and it will copy everything in the internal memory to your memory stick. Then, when you have plugged the memory stick into your computer, you will find a new folder entitled Copy. All your photos from the internal memory of the camera will be in there.
Thanks.
Aug 07, 2009 | Fuji FinePix Z10fd Digital Camera
Internal memory
delete all data from ur internal memory or transfer all data from internal memory to ur memory stick. message will stop displaying
Feb 18, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
From memory to stick
The only way I know how to to do this is to remove the memory stick and download the photos to your computer. Then replace the memory stick and move the photos from your computer to the memory stick.
Feb 17, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Retrieving used memory space off DUOPro stick that can't be viewed on LCD or computer.
You have a bad sector on the memory stick.
Download the data to a computer and format the stick.
Good luck.
Dec 26, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Photos not going onto memory stick
Storage defaults to internal memory (32MB) when Memory Stick Duo is not detected/recognised. Check to see if the Memory Stick's write protect tab is unlocked, or try another Memory Stick.
Apr 24, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
56 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
