Question about Garden
McCulloch Mac 110 saw 600016C 14-852292 Manual
  • 23 Answers
Go this free manual site,no crappy ads just asks for 1 answer when you download a manual. it is a great resource
http://www.manualsonline.com/
Posted on Sep 12, 2010
I asked how to replace the chain on a McCulloch Mac 110. The answer I got was remove bolts on cover. NO VISIBLE BOLTS!
that's a good old McCulloch 110 chainsaw... and
YOUR picture shows the NUT ... (also the one directly above)
Big as LIFE & twice as natural.
Every TREE-MAN I've ever known had the BAR wrench
BEFORE they climbed a tree... (+see below)
Mine are Stihl... 020.
Before that I had a baby SEARS... (really a Homelite).
RIGHT there in he picture you took...
Directly in line with the slot in the chain BAR is one "NUT"
AND an equal sized NUT on the end of the HANDLE
Get the book... or hire out the job if you are UNSURE... That saw is quite precious... simple & valuable.
Seriously!!
May 09, 2016 | McCulloch Garden
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an old mac 110. I believe I need the chain tension adjuster as I am not seeing how to tighten the chain. I can't find my manual so I don't have a part list.
Loosen 2 nuts that are on middle of inside end of bar closest to motor, on retaining plate. Dig out shavings & dirt on outside of that plate there is a recess hole. In it is a adjustment screw to tighten chain. Screw in till it takes up the slack in chain. Retighten 2 nuts when finished.
Jun 30, 2010 | McCulloch Garden
My 110 model chain saw sucks chain oil back into the piston cylinder. When I remove the spark plug and pull the cord it spews out red chain oil. What is the remedy
Did you adjust the oiler? To far CW might cause this. The automatic oiler is driven by an impulse line from the crankcase. If the piston assembly is to deep or has failed there is a direct line into the crankcase.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Mac 110” 600016C may also be a _# instead of letter 600016_03) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Mac 110” IPL number = 11-600016C). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
This is a little complicated so I am going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “11-600016Letter or YourDashNumber”
Every Oil Pump will eventually cross to
Entire pump assembly:
219989 Kit Pump Assy (Oil) $9.29
O-ring
110653 O Ring $0.75
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
I have found McCulloch parts here I can get no where else and they are reasonable.
You can download a complete parts breakdown for your saw here using the IPL constructed above:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Please see if the parts you need are available here. They were not when I ordered them but it is a nice way to say thanks for providing the IPL. I hope you find this helpful.
Lou
Dec 18, 2009 | McCulloch Garden
I have a McCulloch MAC 110, Model 600016C which
The IPL (exploded parts list) for your saw can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600016C_MAC_110_01_77_to_02_83_IPL_95807_R2.pdf
Page 6 item 21.
You have to remove the engine to access it.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
Oct 03, 2009 | Garden
Mcculoch mini mac need owners manual model 600030g
I have a 600016C. I found my manual here:
Beg for manuals thread (ArboristSite)
http://www.arboristsite.com/showthread.php?t=72322
If you need to join to post your request it is free. They are a good collection of chainsaw enthusiasts. GL
Lou
I tried a search for McCulloch 600030G & 600030G without a hit. Post it; someone has what you need.
Sep 21, 2009 | McCulloch Garden
Sawwon't start or run
On my 110 you take off the front section of the saw body to get et the fuel tank and remove it to get at the fuel line. There isn't much room to work in there so be patient.I'll bet your carb needs new diapragms I bought my manual on e-bay.hope this helps
Sep 08, 2009 | McCulloch Garden
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
