Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Pc doesn't recognize it...turns on red light but not blue one.. how do I get it to connect?
  • SimpleTech Master
  • 27,725 Answers
Control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click updare driver
hope this helps
Posted on Sep 11, 2010
2 Suggested Answers
  • 5 Answers
SOURCE: Drive is not working. When
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
Posted on May 08, 2011
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
How do I pair the earpiece with a phone? I do not have my directions.
Well first turn your phone's bluetooth ON Then turn ON your headset.Wait for the indicator light to turn from red to blue. (if it doesn't turn off your headset then turn it back on) Press and hold the Call Control button until the indicator light flashes red and blue. (meaning it's starting to pair) Set your phone to find/add bluetooth device and select your headset from the list found When pairing is successful the indicator light should turn blue and your phone will confirm the pairing.
hope that helps....
Jul 08, 2011 | Plantronics Explorer 240 Bluetooth Headset
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Cannot download pictures. red light flashes when connecting to computer and computer doesn't register the device
For this issue you just need to reinstall the software or driver for your camera. Then restart your Pc. Then you need to connect your camera again to check if the pc will recognized it. You may also try to check if the cable you're using to connect your camera to your pc is not damaged because usually the cable is the one causing the issue.
Hope this help you a bit. Have a great day.
May 18, 2011 | Canon PowerShot S3 IS Digital Camera
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My jwin TH-130 does not work
when i connect my blue tooth it would work but after i stop talking it would disconnect and then i can not connect it back on
Sep 16, 2009 | Jwin BLUETOOTH HEADSET Wireless Headset
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computers & Internet Logo
93 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
