Question about Koss Televison & Video
Battery on KS2708-2 is bad. - Koss Televison & Video
Battery won't charge
try different power supply first then go to ebay and look for inexpensive replacement.
May be the internal aspect of the battery charging system. Some batteries die from bad cells or some die from bad circuitry inside battery. Sometimes the computers circuitry goes bad but everything else is fine. probably bad power supply, or bad battery.
Feb 12, 2014 | Apple Computers & Internet
Tip
Laptop battery does not charging
Following could be the reasons for such failure:- <br /> <b>Computer AC/DC cable is bad not allowing the computer battery to charge</b> <br /> Verify that the AC/DC cable is not bad by removing the battery from the laptop and seeing if the computer can power on without the battery. <br /> <b>Battery is bad and/or old</b> <br /> If the power plug is good it's likely that your laptop battery is bad. If you're using a laptop with Microsoft Windows consider getting and installing BatteryCare on the computer to look at the total capacity of the battery. <br /> Try leaving the laptop connected to the power with the battery inserted for at least two hours. If the battery still doesn't seem to charge, i suggest having the battery and/or the laptop serviced or repaired. <br /> If the computer and/or battery is not in warranty i suggest replacing the battery as it's very likely that it is just a bad battery. <br /> <b>Battery charger board is bad</b> <br /> If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It's recommended that the laptop be sent in to be repaired. <br />
on Dec 24, 2010 | Computers & Internet
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
Chances are bad battery or bad battery circuit. Does the charging light come on? If answer is no, then your power jack or power adapter is bad. If the answer is yes, Its either bad charging circuit or bad battery. Unless you can buy another battery to test it, you will need to take it in to your computer repair shop.
Jan 16, 2009 | Compaq Presario Notebook
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
2.- Battery is bad
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
When i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
Solutions:
2.- Battery is bad
This will fix your problem.
Don't forget to rate my help! :-)
Pablo
Oct 14, 2008 | Computers & Internet
Battery problem...
2.- Battery is bad.
Solutions:
2.- Battery is bad
Pablo
Oct 14, 2008 | Dell Inspiron 6000 Notebook
BATTERY NOT PRESENT
If that is an old battery , it only means that the battery is already dead and needs a replacemenet, but if that battery is new make sure that the battery is charging if its not changing the prokblem can be the battery still....
Hope that helps...........
Sep 18, 2008 | Compaq NC8000 Notebook
Will not start
bad silonoid on starter
the actual cable on starter is bad even though you replaced the positive battery connector the whole cable could be bad
also your new battery might not be a heat battery example= a battery that cannot handle heat and will die on you this indicates a dead cell in battery
bad alternator not charging battery
bad ignition coil
scorched spark plug wiring
dead cell in battery even though the battery can show good it can still be bad
battery's these days are usually refurbished battery's practically every one recycles batterys so its a chance that you got a bad battery try a jump then while vehicle running disconnect the positive post of battery if vehicle dies its the alternator
i myself had to do a battery swap 4 times before i got a refurbished battery without a dead cell this something that is a pain but once you get a good battery then everything should work
Jun 07, 2008 | 1996 Mitsubishi Galant
Televison & Video Logo
Top Koss Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
