Question about Hobart D300 Stand Mixer
Having problems figuring out what is wrong with my older d300 hobart mixer. Mixing dough the other day the agitator slowed down until it stopped, then the motor just buzzed. It did this twice and the second time I couldn't get it to move again, by hand or by turning it on. It was my weekend and I let it sit 2 days and low and behold it spun again, though when I went to finish my dough (in 2nd gear) it wound down and froze again. My tech says I need a new brass worm gear as this one is concave, meaning worn according to him. The Hobart service man I talked to said the gear is supposed to be concaved and that my gear doesn't show enough wear to be a problem. Any thoughts?
    Sergeant:
    Novelist:
  • 193 Answers
Could be a bunch of different things. Depending on how old the mixer is, brushes at the back of the motor. If the brass armature is worn down I have been told its too expensive to replace. They haven't used brushes in 25 years. There are a number of bearings that could be going bad. If the main bearings at the back housing or at the gearbox are badly worn, they may be letting the armature come in contact with the windings. If that is the case the motor will be really hot when running. One obvious question is do you have the proper lubricant and have enough of it? Remove the top cover then pop the inspection hole cover off with a screwdriver. The grease inside should be the consistency of heavy wheel bearing grease. If you had a slug of it on a tablespoon it would stay on it if you turned it upside down. It is a food safe grease available at Hobart parts stores. If the lubricant is thin like motor oil, it is totally worn out and is probably not lubing your bearings at all. One other thing to look at is capacitors. A capacitor looks like a large flashlight battery shaped black object with two wires running from one end of it. It is usually located behind the mixer bowl behind a plate held on by two screws. If your mixer has a "run" capacitor, it may be bad. Remove it and head for WW Graingers or such supply house. Get a capacitor of exactly the same voltage and microfarads. Hook it back up and give it a shot.
Back to the bearings. The main motor shaft should have no play at all if you try to wiggle the shaft up, down or sideways. If it does, the bearings are available at industrial supply houses and are not realy hard to replace if you go slow and have a lot of patience in taking things apart and keeping them in the proper order to reassemble.
Posted on Sep 11, 2010
  • mattseverson Sep 11, 2010
    Thanks! There was plenty of grease in the housing, and now I have it mostly drained and have fresh stuff from hobart to replace it with. I'll take a look at that main bearing tomorrow. The capacitor was suggested by someone else, as it's a cheap replacement, and is on the list to replace. The motor is a bit sluggish starting sometimes, and won't turn at all when the agitator is in a certain spot. I haven't noticed it ever running hot.
    Could the worm gear be the culprit, and is it supposed to be concaved on it's profile? Someone keeps telling me it's worn, though the Hobart tech says it's not worn enough to be causing any problems. Looks fine to me, if it is worn it's extremely uniform along the whole gear.
    Once in a while it will stop for a second when running in second gear, i'll hear a clink and then it continues to run. Kinda heart stopping, and not sure what's happening..
    thanks again for the help!
  • vestxre Dec 07, 2010
    D300's did not have a run capacitor they only had start capacitors. Your symptom sounds like the old repulsion induction motor which used brushes to start rather than a capacitor. The brushes are at the rear of the motor. The rear bearing bracket should have two covers that can be removed without removing the entire bracket. If that's the case then you can see the brushes and the commutator that the brushes ride on. The commutator will burn and pit and the brushes will wear out. If the commutator is too bad to clean with sandpaper you can take it to a reputable motor shop and they can turn it on a lathe. If they are not familiar with this type of motor do not let them touch it. Find someone who is. When the brushes are worn out they will be real short and just barely supported by the brush guide. If that's the case they will need to be replaced. If the motor shop does not have the exact size brushes you can buy a set that is larger and very carefully grind or file them down to fit. Make sure they slide freely through the brush guides. If it doesn't have brushes let me know.
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
Mixer shuts down midway through mixing dough on low speed.Is ther a thermal overload next to contactor that may be overheating
A thermal overload is an option on the D300 and is self resetting. Assuming your machine is being operated at it's full rated voltage, you might have to cut down on the amount of dough you are mixing. If I recall correctly, the relay and overload is located in the base or behind the speed selector plate.
Feb 24, 2010 | Hobart D300 Stand Mixer
Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here: http://www.primasupply.com/images/hobarta200.pdf
You may be overloading the unit. Hope this helps.
Oct 13, 2009 | Hobart A200 Stand Mixer
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
Broken Mixer
in what speed?any noise?what were you mixing?it may be a sheared key or broken gear.let me know.
Jun 28, 2008 | Hobart D300-6036 Mixer
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
May 19, 2008 | Anvil MIX7130 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Second Gear
Sorry so late for the reply.When the product slows down---how slow?can you grab the shaft and stop it from moving?What product are you mixing?
Feb 05, 2008 | Hobart D300-6036 Mixer
Hobart D300 Stand Mixer Logo
509 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
