Question about Princeton Digital VL1918 Monitor
Princeton vl1717 monitor say signal out of range
  • 11,361 Answers
Very faded. hard to read the screen
Try the monitor on another PC. If it is the same way, the TFT Matrix screen itself is Failing; You will have to replace the screen. TCC
Jan 29, 2011 | Princeton Digital VL1717 LCD Monitor
THE BRIGHTNESS OF THE MOITOR IS DARK CAN NOT SEE HOW TO BRIGHTEN WITH CONTROLLS
More likely to have power supply like the failed PRINCETON as shown in my albums.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 25, 2010 | Princeton Digital VL1717 LCD Monitor
Nothing on screen, black, when on
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement board: http://www.lcdrepair.us
Oct 16, 2010 | Princeton Digital VL1717 LCD Monitor
When i connect my monitor to my laptop it shows the monitor is not picking up any signal. why can't i see anything?
Did you use the Fn key and either F5, 6, or 7 to select the internal, external, or both? It depend on the make and model of the laptop.
Sep 05, 2010 | Princeton Digital VL1717 LCD Monitor
Princeton Monitor not receiving signal from signal cable.
First we need to make sure it is not the signal cable or the PC's Video card problem, you need to try it on another PC, we do not want to take the monitor apart unless we have to.
This model has problem with DC filter caps as shown in my picture here which you may want to check them out in the futre also.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Aug 29, 2010 | Princeton Digital VL2018W Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
My LCD Monitor is blinking on & off constantly
It may need a different outlet, if it is not getting proper power. Small chance that the video cable has gone bad, but more likely the monitor is damaged. But try those two things and call Princeton.
Jul 12, 2009 | Princeton Digital VL1717 LCD Monitor
Monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
May 21, 2009 | Princeton Digital VL1717 LCD Monitor
Princeton Digital VL1918 Monitor Logo
167 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
