My friend has a WD-65731 Mitsubishi; a week ago the image wouldn't come , so he unplugged the power cord, plugged it back and the image came. But, he wasn't able to turn it off from the remote any longer, so finally he unplugged the power cord again. Ever since, no more image. The green light will blink for over 1min, then turn off when we plug the power cord, and 60% of times we plug it we'd hear a "click" sound (probably one of the relays), but no image. Any idea?
  • 63 Answers
Try this wait until the blinking stops and then press the button. if still not working replace the lamp and lamp ballast. before changing lamp make sure you clean the dust out using a compressed air.also clean the small fan over the lamp ballast.
Posted on Sep 10, 2010
Mitsubishi wd-65731 screen flickering
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Nov 13, 2016 | Mitsubishi WD-65731 65" HDTV
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
I have the WD-65731 DLP HDTV. The tv will not turn on. Initially, it will power up, and you can here the fan running. The green "timer" light will blink for several seconds. Finally the fan will...
Have you replaced the lamp?? You usually have to replace the lamps around every two to three years. The manufacturer has designed it so you the customer could change it yourself without a technicion. Hope this helps.
May 25, 2011 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WD 65731 - where is the thermal sensor connection that sometimes needs to be resoldered?
does not need to be resoldered. needs to be changed! Any tech that is familiar with Mitsu would tell you that. It's behind the lamp area. Should be done by a Tv technician or you may never get it back together. But not expensive to repair. About $150 parts & labor.
Feb 26, 2011 | Mitsubishi WD-65731 65" HDTV
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Changing the lamp on a Mitsubishi DLP WD-65731, when trying to put back the cartridge, it semms that it does not go all the way in since the two screws do dot reach the nut.
Look inside the tunnel with alight see if the contact plug is straight. Sometimes this plug can get bent to the side a little.
Sep 01, 2009 | Mitsubishi WD-65731 65" HDTV
Mitsubishi DLP WD 65731 TV
the buzzing noise you are hearing is from the lamp ballast as it strikes the lamp. that is quite normal but it should only be momentary. it should not be constant.
Dec 29, 2008 | Mitsubishi WD-65731 65" HDTV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
