Question about GE Wireless Optical Mouse
Where is the battery compartment forthe GE97859.
    Sergeant:
    Champion:
  • 251 Answers
The battery cover slides horizontally in the direction away from the buttons.
Posted on Sep 13, 2010
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Hp g60-630us how to remove keyboard
1) Remove ALL electrical sources.
AC adapter and Battery. Leave the Battery Compartment Door off.
2) Laptop closed turn it over, battery compartment facing Away from you.
3) Looking at the inside edge of the Battery Compartment that is towards you, there are 3 screws to remove.
They are right along the edge that faces you.
There is one in the middle, and one on the right side, that are down in a little indention. (A small drop in the case)
There is one to the left.
Philips head screws. Remove them, place them in a multi-compartment container, and mark the compartment for where they came from.
(DO NOT mix the screws up that you are going to remove)
4) Turn the laptop over, open it.
Carefully lift the Front of the Keyboard up to an angle. (The Front of the Keyboard faces the LCD screen)
DO NOT lift it straight up.
There are plastic tabs that protrude from the back of the Keyboard, and go into the Keyboard Cover.
(The dark rectangular shaped piece of plastic that surrounds the Keyboard, and ends at the Palm Rest, is the Keyboard Cover)
Ease the Keyboard forward towards the LCD screen. Lay it down next to the LCD screen, and on the Keyboard Cover.
You want to be able to access the Keyboard cable's connector.
The Keyboard cable connector is the white connector in the middle, with the ribbon cable leading from it to the Keyboard.
This is a ZIF connector.
Zero Insertion Force.
The ZIF connector is made of two parts. It opens, but does NOT separate into two parts.
The white tabs you see on either side are eased towards the LCD screen.
Use your fingernails.
Push on one 'ear' a little, then go to the other side. Keep alternating back, and forth until the ZIF connector is open. It only opens up about 1/4 inch.
This action opens the ZIF connector, where the flat ribbon cable can be eased out of it.
(To reinstall, line the ribbon cable up in the connector, Insert it until it stops, then squeeze the white 'ears' towards the front of the laptop. {Towards you)
Use EXTREME care when opening, and closing the ZIF connector. If you break it you have to replace the motherboard.
Remove the Keyboard.
Regards
joecoolvette
Nov 01, 2010 | HP G60630US Notebook
Looking for battery compartment
Your battery compartment is more than likely located in the back of the unit underneath the mounting bracket. You need to remove the mounting bracket in order to gain access to the battery compartment.
You can find your manual here:
http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_29897ge1_29897ge1.html
But it doesn't have any reference to your battery compartment for your phone. That I could find anyway.
Feb 10, 2010 | GE 29897GE1 Corded Phone
I have plugged my Alto Coredless but it is not work. The like in the stand is not on.
  1. Make sure you have plugged in the stand’s USB plug into your note book first, and turned on your computer.
  2. Next, on the right side of the stand, there is a connection button.
  3. Press it. You will see lights (A and 3) Flashing back and forth.
  4. While the lights are flashing back a forth, look under the keyboard inside the battery compartment.
  5. Place in battery slot, 2 (AAA) batteries.
  6. Next to the battery slot is a little red button, press it.
  7. The lights on the stand should go out.
  8. Your keyboard is connected to your laptop.
Jul 07, 2009 | Logitech Alto Cordless Laptop...
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
GE Wireless Optical Mouse Logo
18 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
