Question about Peg Perego John Deere Gator HPX
As soon as i plug it in it goes to a green light but does not work
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Check the battery and charger and make sure that they are showing at least 12v
Posted on Jun 08, 2012
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Razr v9 won't charge
well take it back to where you purchased it from..
Aug 01, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Dell Inspiron 1721 - screen goes black
check the light on the power supply that you are hooked up to. before you plug it into the laptop see if there is a green light when the plug has power from the wall. if you see a green light on...good. it means the power supply is responding correctly so far. if you get no green light, then your transformer is out in the psu. if you get a green light and plug in to the laptop and the light goes out, one of two things could be going on. first there could be a short in the psu like the previous tech said, the second more serious issue could be the power controller on the motherboard. they've been known to go out. like the tech before said. try another power supply if you can. but if you are getting a green light on the power supply before you plug it in...there may be another problem with it.
good luck!
Ruben
Jul 18, 2009 | Dell Inspiron 1525 Laptop
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
Peg Perego John Deere Gator HPX Logo
41 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
