Question about New Home 2014LE Mechanical Sewing Machine
Bobin wads up thread;model#ss-2015 serial# 730139143 need a manual?
  • 106 Answers
SOURCE: Problem with spool Thread, please suggest a solution!
This is a tension problem.
In addition to the top thread having a tension adjustment there is the facility to adjust the tension of the bottom(bobbin) thread.
Both these tensions need to be correct to get a balanced stitch and to stop the loose threads underneath the cloth.
It is almost impossible to explain how to adjust the bottom tension you need to be shown.
Somewhere in your manual it should explain how to do this.
Posted on Apr 02, 2008
SOURCE: I need a manual for the New Home School Mate
Parts
Manual
Posted on Jun 21, 2009
SOURCE: thread wadding up
Tension!!!! Its all about the tension! I just had this issue after loosening my tension. So tighten it - the higher the number the tighter the tension. My tension is set at 6 on a Singer 9005 and it seems to work great. By turning it down to 4 I ended up with huge loops/wads of string. Hope this helps!
Posted on Dec 06, 2009
SOURCE: Bobin thread wads up.
just a thought but maybe your bobbin thread is wound on to loose,try to rewind it holding onto the thread to give a tigher tension while going onto the bobbin
Posted on Dec 20, 2009
SOURCE: how to stop bobin thread from knotting
cotton bunching behind material
Posted on May 08, 2010
Threading bobin & threading the machine
If you open up your internet browser and copy over this link
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&dlid=&flang=English&type2=-1 it will take you to the Brother Support page for this model, there is the User Guide there to download.
Threading up is on page 23.
Nov 27, 2011 | Brother LS-2125 Mechanical Sewing Machine
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
Bobin ran out and when I replaced it the thread from the needle keeps getting in a wad around the bobin holder
Sounds like there are spare thread pieces stuck in the bobbin casing/ hook area. Disassemble (it is usually self-explainitory on most machines), clean it out, then re-thread your machine, being mindful of the tension settings. Does this fix it?
Jun 21, 2011 | White Sewing 312 FS
I reloaded my bobin and began to sew. The thread
Sometimes it may look like the bobbin is the problem, when it is actually the machine was threaded with the presser foot down.
Refer to the manual for your machine and recheck the direction the thread is be feeding from the bobbin and that it is going through the proper guide(s).
Always thread a sewing machine with the presser foot up.
When threaded with the foot down, the tension is closed and the thread cannot enter. When you sew, the stitches are loose and loopy.
Feb 24, 2010 | Baby Lock Sewing Machines
Bobin thread wads up. I have a viking mega quilter and frame. I have removed all the threads several times, but each time I try to quilt, the cruise control can only move about an inch, and the bobbin has...
Dec 20, 2009 | Husqvarna Viking 1
Need manual for model 5825c for threading
i was able to find it at www.ifixmachines.com
Oct 18, 2009 | Singer Electronic Sewing Machine
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
New Home 2014LE Mechanical Sewing Machine Logo
113 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
