Question about Bosch SHU9915UC Dishwasher
Bosch dishwasher has high pitched squealing noise when it is filing
  • 311 Answers
SOURCE: Bosch Dishwasher does not stop
Noise indicates a bearing issue at a minimum. That type of issue is really not a do-it-yourself repair. Best to call the repair man.
Posted on Nov 28, 2008
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
SOURCE: Squealing noise
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
Posted on Sep 10, 2008
Problem is with the main pump motor bearing. Water leaking from the face seal enters the front bearing. After some time, the bearing wears out bringing on the loud noise. The motor is easy to remove but the bearing requires some time to remove. I did not have access to a press so I ground off the bearing an replaced it with a shielded 8mmx22mm type. Grainger p/n 1L001. The part is only $9 compared to over $200 for a replacement motor. It takes some time and disassembly of the dishwasher can be difficult but take your time and be ginger with the parts. The root of the problem seems to be the impeller. It screws onto the motor shaft and seems to work loose after time. Since its tightness compresses the face seal, when it loosens water can seep. No way to lock it in place after tightening. Weak design point.
Posted on Sep 24, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Squealing noise from my unit
If it's new, get it replaced. If it's old, you will want to get a new one ASAP and copy your files off at the very least. Try to use it as sparringly as possible until then A hard drive making noise is usually a sign that it's on its last leg.
Mar 29, 2014 | Computers & Internet
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
When water entering the dishwasher there is a high squealing constant noise.
You have a bad water valve here is your link http://www.appliancepartspros.com/part_details.aspx?part_id=3783031
You can gain access to it buy removing the kick panel and front door panel.
Good Luck
Dec 07, 2010 | Bosch SHU9915UC Dishwasher
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
High pitched squeal
sounds like the water pump bearing might be defective. best advice is to replace the pump.
Jun 09, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Nov 28, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Squealing noise
Jul 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU9915UC Dishwasher Logo
2,217 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
