Question about Kenmore Refrigerators
It is hot between the doors - Kenmore Refrigerators
  • 22 Answers
Ok this is a part of the hot gas system a way of eliminating frost should cool down wen fridge is down to temp
Posted on Sep 10, 2010
Freezer door is very hot to the touch on the outside
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
Mar 18, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Only getting cold air they heater.
Sounds like possibly the blend door is broken inside the heater box, I would double check and make sure the coolant level is full, if it is I would take the actuator off on the blend door and try and move it by hand and see if it changes
Nov 02, 2017 | Chevrolet C1500 Cars & Trucks
Overheating ... the rubber edging on the doors is very hot
The rubber edges on the door are suppose to get hot.
some times the fill very hot. many people don't notice this. There is a small mullion heater plased around the doors so that the gasket will not freeze and the door will stick and not open.
Jun 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Door gets warm
Warm is normal hot is not. Too hot is an indication that the condenser coils are overheating due to being dirty or a bad fan motor. See the link below for details I put together on this. Let me know if it helps.
Hot Condenser
Jun 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Door seal between fridge & freezer is hot is this normal ?
No, there is a heater in the seal of the doors to keep the doors from icing up, if it is hot to the touch then the heaters are going bad and must be replaced. You can replace it yourself by removing the door seals, and then removing the heating element that runs the whole door. When you do this make sure that the unit is unplugged.
May 17, 2010 | Kenmore 53092 / 53094 Side by Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Hot band/divider between doors of side by side refrigerator
That is your external humidity control so that your doors do not get condensation. You are going to have to replace it. Go to repairclinic.com and they have you part
Feb 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Nissan pintara ti 91 u12
Your blend door in your car isn't functioning properly. The blend door is a part of the box that your heater core is in.
Jun 09, 2008 | 1991 Nissan Sentra 2 Door
Oven door getting too hot
other than checking the door seal itself, make sure its intact and door closes properly. make sure door' doesnt spring back open after closing does the opening along sid look to be even all the way up the side. maybe the oven door opens more than 90 degrees?? if it does id look into replacing the door hinges
Mar 14, 2008 | Ovens
Refrigerators Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
