Question about LG WM0642H
LE errorMashine get only a litle water and the motor make a noise and after this its coming a L E on the display
  • 15,935 Answers
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
LE errorMashine  get only a litle water and the - wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Posted on Sep 11, 2010
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Flashing LE water in pan
Display Condition LE = Motor Error
First, check wiring connection.
Possible Cause For Error Occurrence:
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Adjust wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Hope helps.
May 10, 2011 | Dishwashers
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
LG LE Error code
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
for more info check out this link:-
http://appliancejunk.com/forums/index.php?topic=1735.0
Dec 14, 2008 | Washing Machines
LG LE Error
The broken wire would be where the wires pass from the bottom of the door into the dishwasher body. A more likely cause may be a motor problem. A number of main motors have had problems with the magnets coming loose or breaking up, resulting in the LE code. You can remove the phillips head screws around the sump cover to gain assess to the impeller, which is attached to the end of the motor shaft. (via a LEFT HAND THREAD screw.) Turn the impeller by hand and listed for noise. Shaft should turn freely, smoothly, and quietly. If it does not, remove the impeller and the cutter bar, remove dishwasher from cabinet, lay it on it's side, and remove four phillips mounting screws from motor and wiring. There is a two year warranty on all parts.
Aug 19, 2008 | LG LDF6810 Built-in Dishwasher
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
LE light on...not filling with water.
ACCORDING TO SERVICE MANUAL, THE "L.E." ERROR CODE SUGGESTS A LOCKED ROTOR ON THE WASH MOTOR. CHECK THE WASH IMPELLER FOR A FOREIGN OBJECT. IF IT SPINS FREELY, CHECK THE WIRING TO THE WASH MOTOR FOR LOOSE CONNECTION.
THE L.G.HAS HAD A HISTORY OF MOTOR PROBLEMS.
YOU SHOULD BE ABLE TO CANCEL THE PROGRAM AND DRAIN OUT THE WATER.
Apr 03, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washer doesn't spin
Try to replace the capacitor and let me know with your results. Good luck!
Sep 01, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM0642H Logo
115 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
