Question about GPS
Is the solenoid a 6 volt solenoid, and if so what limits the voltage to it via the TIP107 darlington transistor?
  • 1 more comment
  • dryjam Sep 15, 2010
    No, the machine is a Christie battery charger Model 500 QRC-2 multi voltage output (6/12/24v).
    The solenoid which switches the output is 6v and is driven by a TIP107 transistor on a control card.
    I wish to know is it meant to be a 6v solenoid, and if it is what or how is the voltage to the solenoid
    limited when the selector switch is put in the 12 or 24v position.I can't find a circuit or shematic
    anywhere.
  • dryjam Sep 30, 2010
    The machine is not a GPS The machine is a Christie battery charger Model 500 QRC-2 multi voltage output (6/12/24v). The solenoid which switches the output is 6v and is driven by a TIP107 transistor on a control card. I wish to know is it meant to be a 6v solenoid, and if it is what or how is the voltage to the solenoid limited when the selector switch is put in the 12 or 24v position.I can't find a circuit or shematic anywhere.
    The selector switch is on the primary side of the transformer switching 240v to the appropriate tapping.
    The device which switches the rectified supply from the secondary side of the transformer is a solenoid
    exactly the same as solenoids on car engines etc.
    The reason why I ask is it meant to be a 6v solenoid is because someone else has been playing around
    with the charger.
    I replaced one power diode on the rectified supply heatsink, and found the darlington transistor on the
    control card open circuit and am about to replace it.
    I would appreciate some technical advice
    Thank you
    dryjam
  • dryjam Oct 05, 2010
    Is there anyone out there who can give me some sort of an answer?
    Am I putting the question/info in the right area?
    dryjam
  • 11,800 Answers
Yes, it's a 6 volt RELAY, not solenoid. The switching system, transistor and all is powered directly from the 6 volt output.
Posted on Sep 27, 2010
    Top Expert:
  • GPS Master
  • 76,109 Answers
What are u talking about here?? is this a GPS which is where u have this listed "Problem with the GPS Devices" is this what u want?
Posted on Sep 10, 2010
Error code p1041 and p1047 02 chrysler sebring lxi 2.7L
Definition of Diagnostic Trouble Code P1041 Saab: Injector Cylinder 4 Shorting To Ground
There is no definition for DTC P1047
CodeDescription P1192 Inlet Air Temp. Circuit Low P1193 Inlet Air Temp. Circuit High P1195 1/1 O2 Sensor Slow During Catalyst Monitor P1196 2/1 O2 Sensor Slow During Catalyst Monitor P1197 1/2 O2 Sensor Slow During Catalyst Monitor P1198 Radiator Temperature Sensor Volts Too High P1199 Radiator Temperature Sensor Volts Too Low P1281 Engine Is Cold Too Long P1282 Fuel Pump Relay Control Circuit P1283 Idle Select Signal Invalid P1284 Fuel Injection Pump Battery Voltage Out Of Range P1285 Fuel Injection Pump Controller Always On P1286 Accelerator Pedal Position Sensor Supply Voltage Too High P1287 Fuel Injection Pump Controller Supply Voltage Low P1288 Intake Manifold Short Runner Solenoid Circuit P1289 Manifold Tune Valve Solenoid Circuit P1290 CNG Fuel Pressure Too High P1291 No Temp Rise Seen From Fuel Heaters P1292 CNG Pressure Sensor Voltage Too High P1293 CNG Pressure Sensor Voltage Too Low P1294 Target Idle Not Reached P1295 No 5 Volts To TP Sensor P1296 No 5 Volts To MAP Sensor P1297 No Change in MAP From Start To Run P1298 Lean Operation At wide Open Throttle P1299 Vacuum Leak Found (IAC Fully Seated) P1388 Auto Shutdown (ASD) Relay Control Circuit P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM P1390 Timing Belt Skipped One Tooth or More P1391 Intermittent Loss of CMP or CKP P1398 Mis-Fire Adapter Numerator at Limit P1399 Wait To Start Lamp Circuit P1403 No 5 Volts To EGR Sensor P1475 Aux. 5 Volt Output Too High P1476 Too Little Secondary Air P1477 Too Much Secondary Air P1478 Battery Temp Sensor Volts Out of Limit P1479 Transmission Fan Relay Circuit P1480 PCV Solenoid Valve P1482 Catalyst Temperature Sensor Circuit Shorted Low P1483 Catalyst Temperature Sensor Circuit Shorted High P1484 Catalytic Converter Overheat Detected P1485 Air Injection Solenoid Circuit P1486 Evap Leak Monitor Pinched Hose P1487 Hi Speed Rad Fan CTRL Relay Circuit P1488 Auxiliary 5 Volt Supply Output Too Low P1489 High Speed Fan CTRL Relay Circuit P1490 Low Speed Fan CTRL Relay Circuit P1491 Rad Fan Control Relay Circuit P1492 Battery Temperature Sensor Voltage Too High P1493 Battery Temperature Sensor Voltage Too Low P1494 Leak Detection Pump Switch or Mechanical Fault P1495 Leak Detection Pump Solenoid Circuit P1496 5 Volt Supply Output Too Low P1498 High speed Rad Fan Ground CTRL Rly Circuit P1594 Charging System Voltage Too High P1595 Speed Control Solenoid Circuits P1596 Speed Control Switch Always High P1597 Speed Control Switch Always Low P1598 A/C Pressure Sensor Volts Too High P1599 A/C Pressure Sensor Volts Too Low P1602 PCM Not Programmed P1680 Clutch Released Switch Circuit P1681 No I/P Cluster CCD/J1850 Messages Received P1682 Charging System Voltage Too Low P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit P1684 Battery Disconnected Within Last 50 Starts P1685 Skim Invalid Key P1686 No SKIM Bus Message Received P1687 No Cluster Bus Message P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 DTC Detected In ECM Or PCM P1694 No CCD Messages Received From ECM P1695 No CCD/J185O Message From BCM P1696 PCM Failure EEPROM Write Denied P1697 PCM Failure SRI Mile Not Stored P1698 No CCD Messages Received From PCM P1719 Skip Shift Solenoid Circuit P1740 TCC Or OD Solenoid Performance P1756 Governor Pressure Not Equal To Target At 15?20 PSI P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI P1762 Governor Pressure Sensor Offset Improper Voltage P1763 Governor Pressure Sensor Voltage Too High P1764 Governor Pressure Sensor Voltage Too Low P1765 Trans 12 Volt Supply Relay Control Circuit P1899 Park/Neutral Position Switch Stuck In Park or In Gear
Read more at: http://www.obd-codes.com/trouble_codes/dodge/
Copyright © OBD-Codes.com
Jul 26, 2015 | Chrysler Cars & Trucks
How do i test a a darlington ,2sd2560
Here. This is for standard transistor. When they mention 0.6 or 0.7 volts, yours should have double that. Everything else is the same.
Nov 16, 2014 | Televison & Video
Stage 100 blowing fuse,loud hum
Hi,If your blowing fuses then the problem is most likely to be faulty bridge rectifier or darlington output transistors.All readily available and not too expensive.Circuit diagram on Fender site or net easily found.Thanks Fender good customer service.
Oct 16, 2013 | HHB Radius 50 Tube Amplifier
I received a PV1500 amp that had only one channel working. i decided to open the amps to check the other channel being that i usually repairs amps. up on analyzing the damage circuit board of that channel,...
It seems there's another component (a capacitor, a diode, etc) causing a short circuit to triac and transistor, or there's an over voltage on this stage, please check if the voltage is according to the one feeding the good channel.
Mar 01, 2011 | Peavey Music
I have a problem with Behringer mix ( UB 1832-pro) does not work multi-efects. I need a power supply plan. This link ( http://elektrotanya.com/http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m...
Try this link:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
On page 11 is the power supply. The TIP31 (T1) is the regulator for the +15 volt rail. The TIP31 is connected as a Darlington with a BC846 (shown on the schematic as "846"). This is a surface mounted tiny transistor.
NOTE: This regulator is NOT a voltage regulator but is actually an ACTIVE ripple filter consisting of the 2.2K resistor (R6) bypassed by the capacitor C4 (100mfd/25v). R8 (120 ohm) serves as a parasitic suppressor and base surge current limiter for the BC846 transistor (T4).
Feb 23, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
This is a Wagan 2003-6 400Watt with USB DC to AC Inverter. Worked great for almost a year. Recently fan was varying in speed under load. Then finally blew my vehicle cigarette lighter receptacle fuse. ...
A few thoughts on this. With the transistors, if these are a darlington style of transistor, it might show a short on a good transistor. The USB "transistor" is a voltage regulator, 12v to 5volts dc. With the inverter input, some inverters use a diode in the input to protect against connecting the inverter by reversed leads. This diode might be shorted and be causing your problem. If it comes to changing the transistors, it might be cheaper in the long run to buy a new inverter. The transistors might be problematic and might not be the only thing problematic. Experience here talking!
Feb 05, 2011 | Wagan 20036 400 Watt Power Inverter Corp
While sitting for hours delivering 300 volts, my Ortec 456 power supply went to over 4000 volts all on its own. Not a pretty sight. Ortec 456 is a 0 to 3000 volt power supply.
The large darlington transistor (Q5) that regulates the voltage to the high voltage inverter is most likely shorted. Let me know if I can assist (eBay name koifan).
Jan 27, 2011 | Health & Beauty
Tr51 gets hot
This is part of a Darlington Amplifier section of voltage regulation to the Final transistor it may be getting hot for various reasons one you may be taxing its resources by long key downs or you may have too much voltage going into the radio it should only be supplied with 13.8 Volts Maximum more than that (Volting the Radio) Will over work thhis transistor and eventually burn it out.
May 10, 2010 | Galaxy Radios DX 77HML Base CB Radio
Explorer, 2000; 4.0 EFI: Engine runs fine in neutral & responds well when accelerator is depressed; shift to reverse or drive & engine runs very rough....with no power whatsoever. Scanned...
P1747 * EPC, wiring, PCM EPC solenoid circuit failure, shorted circuit or output driver Voltage through EPC solenoid is checked. An error will be noted if tolerance is exceeded. Short circuit causes minimum EPC pressure (minimum capacity) and limits engine torque (alternate firm). Go To Pinpoint Test
The EPC solenoid is shorted or the electrical circuit (wiring) or the transistor (driver) inside the computer is fried. do you know how to test a computer controlled circuit ?
How to test computer transistor driver without scan tool
Do you know how to find the circuit in question ?
And you are correct about these two codes as being not related . Do you know what evaporative emission system is ?
Wells EVAP Training with Sgt Tech P0440 P0441 P0442 etc
The Evaporative Emission Control System (EVAP) is used to prevent gasoline vapors from escaping into the atmosphere from the fuel tank and fuel system. The EVAP system usually requires no maintenance, but faults can turn on the Check Engine light and prevent a vehicle from passing an OBD II plug-in emissions test.
EVAP Evaporative Emission Control System - AA1Car.com
http://www.bbbind.com/free_tsb.html you can find free wiring diagrams here . Do you know how to use a wiring diagram ?
P1451 - EVAP Control System Canister Vent Solenoid Circuit Malfunction Monitors the canister vent (CV) solenoid circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified canister vent duty cycle by PCM command.
  • VPWR circuit open
  • CV solenoid circuit shorted to PWR GND or CHASSIS GND
  • Damaged CV solenoid
  • CV solenoid circuit open
  • CV solenoid circuit shorted to VPWR
  • Damaged PCM
To verify normal function, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV will indicate 0% duty cycle and the voltage approximately equal to battery voltage. When the valve is commanded fully closed, EVAPCV will indicate 100% duty cycle and a voltage drop of 4 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function. This is another electrical circuit problem .
Do you know how to use a DVOM - digital volt ohm meter ?
Do you know that P1747 (electronic press control solenoid short circuit) Is a transmission problem . This solenoid controls the fluid pressure .
May 10, 2017 | Ford Explorer Cars & Trucks
GPS Logo
42 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
