Question about Jensen JPA1150M Car Audio Amplifier
My amp power light wont come on but the stand by light comes on for about 4 seconds then goes out. And the Jensen logo on the top lights up blue but the power light never comes on.
Vulfen
  • 5 Answers
SOURCE: Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Posted on Jul 15, 2007
jerryg50
  • 1689 Answers
SOURCE: Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Posted on May 01, 2008
  • 631 Answers
SOURCE: amp works when beaten
It sounds like you have a broken connection in the amplifier. The first thing to check is the fuse. Sometimes the contacts become weak on the fuse holder and the connection becomes intermittent. Any other troubleshooting would require opening up the amp. Any repairs would require resoldering the broken connection.
Let me know if you have any other questions.
Posted on Sep 24, 2008
Duncan
  • 218 Answers
SOURCE: No sound comming from amp
If it only worked for about a month, then you probably did not get your speaker load right. Check that out before you repair the amp and put it back in. Good luck.
Posted on Nov 11, 2008
  • 150 Answers
SOURCE: similar prob.did the 12 steps on how to install
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
Posted on May 19, 2009
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
My sony bravia 46" it wont continues to turn
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Jun 21, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Power to the amp but the blue light doesnt turn on
probably a blown capacitor open it up and look at the capacitor see if any one of them are curvy on the top blowend
Jun 27, 2009 | Alpine MRP-M350 Car Audio Amplifier
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Amp works when beaten
Sep 22, 2008 | Jensen XA2250 Car Audio Amplifier
Jensen LXA400
Apr 12, 2007 | Jensen LXA400 Car Audio Amplifier
Jensen JPA1150M Car Audio Amplifier Logo
176 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
