Question about Panasonic FP-7735 Black and White Copier
Dark, streaked copies - Panasonic FP-7735 Black and White Copier
  • Panasonic Expert
  • 1,326 Answers
I would first start by cleaning the optic's & cleaning the primary & transfer corona wires and do a general cleaning and that may solve your problem? Good Luck
Posted on Sep 12, 2010
What causes black streak lines on the entire copy
open the right door and look at the drum, lines on it? If not, its the hot section/fuser. -Carl
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
Dark streaks on copies
replace the the drum iff not that the the fuser
Jan 03, 2014 | Konica Minolta Minolta DI1610FP...
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
May 03, 2011 | Sharp Office Equipment & Supplies
Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
Whit
Item, Inc
Aug 18, 2010 | Canon C130F Black and White Copier
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Copies Coming out Dark
Please give modell number and name. Cant give you a advice out into the blue :-)
Sep 11, 2007 | Brother 6-In-1 Printer/Fax/Copy/Scanner
Panasonic FP-7735 Black and White Copier Logo
73 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
