I need bit more detail about dark and cloudy screen at right side.
Does this change in screen start from center part instantly like it divides screen in two sections or screen gets darker gradually?
Thanks.
OK, two possibilities for that symptoms.
Either T-Con board is defective and causing problem or lcd panel itself got bad and need to be replaced.
T-Con board is located at top center of lcd panel if you see it from rear and board will be covered under metal shield. Local tv repairman will help you to replace that board as it needs expertise and skills.
If lcd panel is defective then it would be costly fix like approx 80% of new tv price.
Thanks.
Thank you.
it divides screen in middle. you can still see picture but only darker.
thank you for your help
