Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
  • 377 Answers
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Posted on Sep 11, 2010
Dip tube size and length and type of end for Rheem PVW50 water heater
All dip tubes on water heaters smaller than 75 gallons are 3/4" male pipe thread to screw into the heater. As for length, go to a plbg supply and ask for a dip tube for a 50 gallon heater, and if it is too long, cut it. I believe that Home Depot also has them right out on the floor for sale.
Feb 27, 2018 | Rheem Water Heaters
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rudd water heater leak. I have a six-year-old unit. I suspect it is no longer covered by warranty. Can it be repaired or must it be replaced?
depends were and whats leaking, have an engineer look it over,see if it can be, and how much it will cost to repair,compaired to the cost of replacing it
Sep 07, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 50 gallon electic water heater that seems to be leaking from the on/off lever at the top of tank. Do you have a replacement part for the on/off lever? Thanks, Cindy
If you are talking about the water valve on the cold water inlet it should have a nut under the lever if it is a quarter turn ball valve.If so you can remove the nut that hold the lever on and carefully tighten the nut by turning it clockwise.This should stop it leaking if it is coming from around the stem. If it is a globe type valve there should be a packing nut that goes around the stem under the handle. Tighten this nut carefully to get leak to stop. If it is leaking anywhere else then you will need to have the valve replaced.They are available at almost any hardware store.Thank you.
Aug 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Oct 20, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 41V50N and water is leaking from the bottom do I definitely have to replace it?
Check to make sure that the leak is not from the drain or the pressure relief valve, otherwise it is time to replace....
Jul 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
227 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
