Question about Kenmore Sewing Machines
Kenmore 100 stitch 385 It will not pull the bobin thread up into the stitch. It does all the fancy patterns but the bobbin thread does not ingage in the stitch. Please help
    Genius:
  • 1,788 Answers
Make sure that you have the bobbin threaded correctly, and that you have a tail of 3-4 inches held in your left hand until the top thread catches, make sure you move your handwheel towards you and your needle is inserted with the flat side facing the rear of your machinine.
Posted on Sep 11, 2010
Testimonial: "I found the answer, through searching the site. It was the p-roblem in many machines. I put in a new needle and wa la bobbin thread came up! Thanks"
I have a Kenmore 385 19153 the thread is breaking any keeps jamming in the bobbin
Could be threaded incorrectly. Remove the thread from the machine. Put in a brand new needle.. ALWAYS RAISE the presser foot and rethread the top thread from the beginning. (AVOID old or bargain bin thread--might even try a different type of thread.) Check that the thread path is correct. Then put bobbin in the bobbin case and thread it through the tension. Check that the bobbin is turning the correct direction in the bobbin case. Install the bobbin case in the machine. Start out with the top tension set about the midway point and then tweak it from there to get the appropriate tension.
Pull the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while you slowly take the first few stitches.
If you continue to have issues, then you may need to have your machine serviced. It could be out of time or perhaps there is a snag or burr that is catching the thread.
Nov 13, 2017 | Kenmore Sewing Machines
Bobins
To "wind" a bobbin you can:
1 - Look in your book
2 - Google : how to thread a bobbin on a kenmore "12 stitch"
3 - Youtube https://www.youtube.com/watch?v=Fe11QQubfqw
4 - Ask a friend
To "make a bobin"
1 - Get some 0.5mm stainless steel
2 - Cut two 19mm circles out of the 0.5mm steel
3 - Drill a 6mm hole in the center of each circle
4 - Solder (silver solder work the best) the 2 circles together with a 6mm round by 9mm tall cylinder in between the two 19mm circular pieces.
Mar 13, 2014 | Husqvarna Viking 1
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
Sep 10, 2010 | Kenmore Sewing Machines
Unable to get the bobin thread to the top of
Hi. The most likely reason for this is that the needle is not inserted correctly. There is a flat side to the needle shank that has to be inserted facing a particular way--to the right as you're facing the machine, or to the left, or to the rear, facing away from you. Most modern machines need the flat side of the needle facing to the rear, so try that first. Also make sure the needle isn't bent or dull.
Hope this helps!
Robbie
Apr 08, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
I have an older New Home Sewing machine XR-V11 electronic I have figured out the threading, bobbin, regular stitching and back stitching. It has alot of fancy stitching on it I can get the dial to move to...
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Mar 06, 2010 | New Home HF-2022
Why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
Dec 02, 2009 | Kenmore 15516 Mechanical Sewing Machine
Thread gets caught on the bobbin holder and won't
Hello there:
have you tried to adjust your stich pattern and slowed down your feed rate also doublecheck the bobin to ensure that it is installed fully in the casing and is not warped at all ok?
regards mike
Aug 18, 2009 | Kenmore Sewing Machines
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
Sep 05, 2017 | Sewing Machines
Sewing Machines Logo
261 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
