Question about Dell Precision 340 PC Desktop
What is the max hardrive for a dell precision 340
    Scholar:
  • 128 Answers
Hi!
As of our current technology ALL Motherboard can support the most biggest hdd capacity which is 2TB (Terrabyte). You can even use a 10 TB single hdd on your motherboard if you have one.
Regardless of brand and model it will still be the same.
Cheers~
Posted on Sep 10, 2010
Remove motherboard
Suggest you look on the Dell site for a 'service manual' ...
Apr 21, 2014 | Dell Precision 340 PC Desktop
Dell Precision 340 Power Button Doesn't Work
If you can get the side off, then you should be able to see what holds the front panel on. A lot of the Dell systems have a slide lock on the top of the tower that you pull back on to release the front panel.
Aug 05, 2012 | Dell Precision Workstation 340 Replacement...
I was given an old Dell Precision 340 formatted with windows xp. i want to return the system to its original factory settings. I've tried to follow several different solutions to no avail. I was told...
If the previous owner ever formatted the disk, then they probably wiped out the hidden restore partion if one existed. This link will take to you to a restore disk ordering site. You can order the disks to restore to factory. $29.99
http://recovery-disks.com/dell/precision/dell-precision-workstation-340.html
OR you can go to Dell and find/order restore disks there..
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen&~tab=2&~ck=anavml
Jul 17, 2011 | Computers & Internet
Can I add a PCI graphics card to my dell 340 to get a dual monitor
Yes you can. Depending on your model you can install
  • In the small desktop computer, up to two 32-bit, 33-MHz PCI cards.
  • In the mini-tower computer, up to four 32-bit, 33-MHz PCI cards.
  • One 32-bit AGP card. The expansion slot supports an AGP 4x (low profile in the small desktop computer) card operating at 1.5 V.
You can NOT install ISA expansion cards.
Find more details here and here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Apr 08, 2010 | Dell Precision 340 PC Desktop
Dell 340 will not recognize my cd or dvd drive.
check if you see any light on the drive, if yes. then the power is there and then the problem is with the data cable of the cd drive. try to repalce the cd drive with another cd drive. if it still doesnot work and if the same cables work with the hard drive, then the cd drive has gone bad. and if the new drive also doesnot work then reinstalling the operating system should fix the problem only and only if it appears in the bios. if it doesnot appear in the bios. then the problem is not of the operating system. then its the motherboard.
Oct 13, 2009 | Dell Precision 340 PC Desktop
My hard drive won't turn on I think it crashed I need to know where is the reset buttoon?
there is no master resest button , if your hardrive is not working it is most likely dead or has a loose wire.
hardrives arent designed to last for ever,what you can try to do is unplug the mains plug leave the pc for an hour or so , and then before pluuging it bavck in press the power switch this should clear all power from the motherboard and power supply.
you can also try reseting the cmos by removing the small battery on the motherboard.
it is most likely you H/d is dead,following benwabnicks advice have you been able to see the H/d in bios. to enter bios press f10 or another key immediatley after powering up the pc, it usually tells you on screen press enter or f10 or another key to enter bios or setup.
let us know how you get on
Thanks for posting
May 24, 2009 | Dell Precision T3400 PC Desktop
Uprgade information
for this call dell technical support they have the details reagrding what is the maximum configuration your system can support and they will help you for free in this,
Further Queries are welcome
if you think my solution is helpfull please do rate me
Feb 20, 2009 | Dell Precision 340 PC Desktop
Dell Precision 340 will not boot past the bios
It is possible that one of the drives are causing the proble. Disconnect all drives Hard drives, CD, DVD, BLUERAY,Floppy etx and turn the system on if it boots then shut it down and connect the drives one at a time until you find the one at fault.. If this fails then the problem resides in the main board itself, YOu said you cleard the cmos, try reseating the processor (removing and then putting it back) then flashing the bios (clear the cmos) ,, if that fails then you may need to replace the mainboard.
Nov 28, 2008 | Dell Precision 340 PC Desktop
Dell System Precision Workstation 340 will not boot
open your cpu then remove cmos cell for 10 seconds.
alos near cmos u see jumper it is set in 1-2 posirion change it to 2-3 thne power up the computer then again set it to itsd original positionmeaNS 1-2 .
Nov 26, 2008 | Dell Precision 340 PC Desktop
Dell Precision 340 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
