Question about GE Ovens
WIRING DIAGRAM FOR RAC12-200-48 WHERE DO I CONNECT THE TOP ELEMENT FOR THE GRILL AND THE BOTTOM ELEMENT FOR REGULAR OVEN OPERATION THANHS RICHARD DUCHARME
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1462 Answers
    SOURCE: delonghi esf461st oven not heating up
    grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
    Posted on Sep 06, 2008
    SOURCE: replacing electrolux eob944 fan oven grill element
    ...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
    Posted on Jul 08, 2009
    ianem
    SOURCE: Top oven and grill of my Diplomat ADP4520 double
    there is a problem in the wire connection that can cause a short circuit.
    Posted on Nov 11, 2009
    barkencoa
    • 3463 Answers
    SOURCE: fan and grill works, grill actually cooks but oven
    Without a doubt this is the element that is faulty.
    It is located at the rear of the inner oven compartment behind a removeable cover.
    Posted on Mar 30, 2010
    My wonderful oven is malfunctioning. The grill works fine and the fan spins but the oven won't heat up at all. Any suggestions much appreciated.
    Sorry Anon, but there are tons of ovens manufactured, so with no make & model I can only suggest that you try to check to see if you have any fuses or breakers popped - You'll have to find these yourself.
    Next the grill is the top oven element, the oven heat comes from the bottom element as heat rises. Is this element burned out?
    You will need a multimeter and a screwdriver.
    Remove the back of the oven, after you have pulled it out from the wall and unplugged it from the wall. Then unscrew whatever portion of the back of the oven that will expose the bottom element, disconnect one end of the element from any wiring of the stove, and using the meter on Resistance setting, see if you get a relatively low resistance reading - If not, then the element may have died.
    If you can't figure how to access he ends of the bottom element, then you need to get someone who can help you or sorry, call in an appliance repairman
    Mar 12, 2015 | Ovens
    Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
    Request the wiring diagram directly from Kelvinator.
    Jun 25, 2014 | Ovens
    Grill not working after replacement element - any ideas?
    I would say you are right on your wondering. look at your manuel and it will show you a diagram
    May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
    Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
    Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
    Feb 11, 2011 | Ovens
    Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
    First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
    The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
    To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
    So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
    Best of luck
    Nov 23, 2010 | Stoves 720EF Electric Double Oven
    How do i work the grill?
    Nov 21, 2010 | Stoves 720EF Electric Double Oven
    Grill trips my electrics on Stoves 720EF
    I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
    Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
    Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
    BE CAREFUL.
    Jun 06, 2010 | Stoves 720EF Electric Double Oven
    Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
    it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
    regards
    richard saupe
    appliance repairman
    Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    No Grill operation for stoves 720ef
    Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
    With your fault, can you here the switch operating, if not it just may be stuck?
    Dec 12, 2009 | Stoves 720EF Electric Double Oven
    Ovens Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
