Question about GE Profile PSS26MGS Side by Side Refrigerator
The ice machine wont turn so the ice wont come out, the water works ok
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
MY ICEMAKER IS NOT GETTING WATER IN THE FILL TUBE IN THE BACK OF FREEZER
HI .IF WATER SUPPLY IS OK CHECK ICE LEAVER FIRST.IF ON THEN CHECK VALVE.IF OK CHECK ICE MACHINE ICE TRAY.FILL UP WITH WATER IF EMPTY.IF NOT THEN IT COULD BE YOUR ICE MACHINE .GOOD LUCK ali
Jun 24, 2012 | Hotpoint Refrigerators
Ice maker wont make ice but water still works
Most machines use a dual valve with 2 separate solenoids. 5a2f3bb.jpgOne for water one for ice. I suspect the one for ice is bad. The solenoid might be ok but the innards fouled.
May 17, 2010 | Refrigerators
Ice maker wont work
Good day,
The best way is to perform a step by step procedure. It will get you there. Skip any step you have resolved.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Apr 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer leaks water even with ice maker water turned off
The only water that can come out of the freezer if the water is turned off is defrosted ice that cannot go to the tray at the bottom of the machine since the drain hole is blocked. See if any water is in the tray under the machine. Probably dry as a bone. If so carefully remove the back panel in the freezer, after you have defrosted some of the ice buildup. If you find lots of Ice the defrost circuit isn't working. If you find frosty ice the circuit may be OK but the drain blocked. You MUST melt ALL ice on the coils, and in the drain pan below the coils. Use a turkey baster to shoot hot water into the drain hole until it is free of ice and water flows freely into pan below. Find the defrost thermostat and turn it manually with a screwdriver and see if the defrost heater gets hot (be careful, gets very hot) timer should turn very slowly when powered. If not hot but timer turns on its own the defrost thermostat is probably defective.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser wont dispense. Sounds like it egages
Remove the bin and you probably have ice caught in the auger .
Jun 30, 2009 | Refrigerators
Machine frozenas kept in outhouse. Have been defrosting it with a small heater. Now water in OK, but cycle not working. Now full of water, but wont drain away! Tried to empty filter, but appears stuck....
Probably drain outlet hose and water in pump frozen, you will have
to wait for the the ice to melt in the hose, but if you put some hot water in drum, that should melt any ice in pump.
PLz rate my solution.
Thanks
Jan 07, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
GE Profile PSS26MGS Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
