Question about ASUS Eee PC 1000H Laptop
It resets its self constantly as soon as it boots up
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 18, 2010
Uniden Bearcat BCD996T will not squelch, just has constant noise on every channel. Any ideas on what has happened
Have you done a reset just to make sure something such as static did not change the software in the microprocessor? Try that before you go to a repair shop.
Dec 03, 2014 | Uniden Radio Communications
1998 plymouth grand voyager resetting it self
If the ECM keeps resetting itself, try disconnecting one or more sensors with engine running, If you get no codes after this the ECM is malfunctoning
Nov 15, 2014 | 1998 Plymouth Grand Voyager
Dell inspiron one is stuck in a constant repair loop. NO option for repair or factory reset . Please help. Thank you
Try restoring failsafe option in the bios F9 and save it.If that doesn't work to get you out of the cycle try turning it off as soon as it tries it again 2nd time by holding down the power button.It may go to safe mode from there.when restarted.Hopefully you can get somewhere from there.If not try tapping F8 from an initial boot not from restart.
Aug 29, 2014 | Computers & Internet
How to set dell 530 to boot from usb
During start up of your system constantly hit either F2 or F12 to enter Bios.
Once in Bios you can configure your boot settings to boot from Your USB device. Bios is pretty self explanatory even for those of us not to familiar with it myself even. Unfortunately mouse is not usanle in Bios. I've had to go to Bios many times on older systems just to boot from cd/dvd Also to correct problems others have made in the boot settings.
Anyway In Bios there is a little summary of each changeable feature within it. Once you make your selection(s) make sure to save changes so you do not have to keep resetting them to your own personal preference. You should be asked upon exiting if you want to save. Your machine should automatically restart and ask you to press any key to but from your device. If you do not hit any key your machine will but normally from harddrive and you will have to restart the system and wait for it to ask again.
Apr 19, 2014 | Dell Inspiron 530 Desktop Computer
My phone is automatically switch off
Talking on the phone with a bluetooth headset and self-rebooted.
Playing abduction and crashed. Self-reboot constantly at the X screen
Took battery out for 15 second, and tried again, same thing.
Did it a second time to fix it.
- reading google.com/reader and crashed. Self-reboot constantly at the X screen
Did a factory reset to see if it helps.
During market downloads of apps, crashed again and rebooted
Phone used edge more than 3g lately in the past few days.
After factory reset, using 3g again.
Had the phone for 3 weeks, so the tech support guy said I can only get it repaired or replaced by a refurb unit...Sounds like a bad deal to me...
and to make it even worst, I bought the google dev g1 a few months ago before this...$1k down the drain...
Feb 14, 2012 | Cell Phones
The phone switches it self soon after being booted
First of all check the battery connection , clean the terminals, check the charge on the battery. Now on booting if the phone has hung up then there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 09, 2011 | Cell Phones
When I turn on my toshiba satellite 5005-S504, it will go through the motions of boot-up, then it will suddenly shut it's self off then turn it's self back on. It won't stay on. Please help.
restart your pc but as soon as it powers on (even before you see anything on the screen), repeatedly tap on f8 until it takes you to a menu. choose the option for last known good configuration. if it still doesnt boot up, repeat the same procedure but this time choose the option for safe mode then once it boots to safe mode, just do a system restore
Apr 04, 2011 | Computers & Internet
I hit power button it boots the shuts off bout all the buttong work still and thers noting on the scrren its black
do a hard reset...unplug ur comp take ur battery out(if its a laptop) if its a desktop then unplug it and push the power button for 30seconds to discharge all the stuff the put everythingas normal...and when it turns on leave it alone for abit and windows will fix its self soon..
Jan 10, 2010 | Gateway M-6866 Notebook
Won't boot up. It just gets to a certain point in the start up,then says it has to shut down to save files.
do a hard reset...unplug ur comp take ur battery out(if its a laptop) if its a desktop then unplug it and push the power button for 30seconds to discharge all the stuff the put everythingas normal...and when it turns on leave it alone for abit and windows will fix its self soon..should work i did it..
Jan 10, 2010 | HP Computers & Internet
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
ASUS Eee PC 1000H Laptop Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
