Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
My Vr3 630 shows ''wrong region'' on normal dvd. How can I fix that? Please explain step by step.
I have a GPX portable DVD player that is showing wrong region. It was playing these same disks before and now it will not?? Any help?????
Commercial DVD disks are "keyed" to a specific "region".
USA is in "Region 1", and Europe is in a different region.
Some DVD players allow you to "switch region", but only up to FIVE times, and then it "locks" into one region.
Apr 21, 2014 | Sanyo DVW-5000 DVD Player/VCR
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
Aug 12, 2012 | LG Televison & Video
Wrong disc
this problem is normally a fault due to using a dvd disc that is not from your country region. check the dvd box and make sure the region code matches your country that you a veiwing it in.
Jul 12, 2010 | Sungale DVD-2026 DVD Player
NESA DVD-1002 Car DVD - Region Codes
Oh that sucks... I had the same issue with a Sony Xplod Indash DVD Player, You have to contact the Manufacturer, They will either replace the system, or explain to you how to fix it, In my case they replaced mine.
Apr 14, 2010 | Nesa Vision DVD-1002 Car DVD Player
DVD movies form Amazon show in India ''wrong region''.
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Apr 03, 2009 | Philips Televison & Video
Wrong region code
Not much can be done about this other than returning to get a refund since it is Oman don't expect any joy
Aug 21, 2017 | Samsung 1000W 5.1-Ch. Home Theater System...
WRONG Region error . Philips DVD65K
Each DVD player is designed only to read discs froma certian region of the globe, and they are labelled 1 through 6 (or ALL). Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 21, 2008 | Philips PET710 Portable DVD Player
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Region
Follow these steps to make your DV3500 a region free player. With the power to the DVD player on...
OPEN TRAY
PRESS SETUP
TYPE IN NUMBER SEQUENCE 9 3 0 1 0
PRESS STEP
PRESS SHUFFLE
PRESS NEXT
CLOSE TRAY
POWER OFF
POWER ON
The DVD player should then be region free.
Best of luck!
Feb 21, 2008 | Teac DV-3500 DVD Player
Region Problem
To change the region perform the following actions: Power on Player /Open/ (/eject/), then on remote /stop/ then /9735/ and then go to /setup/ and choose no region. It should know play all disks. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Jamo DMR 60 DVD Player/Receiver
Car Audio & Video Logo
60 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
