Question about Kenmore Refrigerators
Our ice maker has stopped making ice. I checked the water filter, it is fine. I checked to see if there was ice blocking the mechanism, there was none. We moved the temp up half a notch ... 24 hours still no ice. what else could it be?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Sep 11, 2010
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Ice maker stopped working.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 01, 2008 | Amana Refrigerators
Kitchen aid superba fridge - ice maker not working .. water dispencer is
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
WH95TP-03, won't make ice
The machine in let water filter is block clean the filter and check the water flow
Jun 24, 2008 | U-Line Icemaker
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
