Question about General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V
I am installing a sub panel in a detached building from my house. Which is 100 ft away. I plan to have four separate circuits. One that will service a ceiling fan and 3 for plug ins that will only run a TV and maybe a 110 air conditioner. I plan to use a 60 amp breaker from the main panel and run 6/3 wire to the sub panel that has a 100 amp main breaker will this work?
  • 760 Answers
You could use 6/3 with ground. You must take an equipment ground conductor along with your current carrying conductors. Still drive a ground rod at the building, and add a seperate ground bar in the sub panel. Connect your equipment grounding conductor from main building along with the equipment grouding conductor to the ground rod. Do not bond the neutral in the sub panel to ground. Be aware you will still have some voltage drop, so a 220V air conditioner might be better.
Posted on Sep 24, 2010
I have a 200 amp main with sixteen seperate rooms each with two or three light fixtures and four power outlets. In addition I need to have six or seven 220 lines for the house. For the dryer stove furnace...
Hard to tell from your description but the best way is to add a separate box if the main breaker box doesn't have the capacity. the separate box would be done with #4 copper to the main lugs and it would need a main. You could also put in a larger 220 in your main panel depending on the demand of the subordinate panel you'll be installing.
Aug 28, 2014 | Electrical Supplies
I PLAN TO RUN AN EELECT. WIRE 100 FT. FROM MY HOUSE TO A STORAGE BUILDING. THE CIRCUIT I'M CONNECTING TO IS 12 GA. WOULD THERE BE ANY BENEFIT TO USING 10 GA WIRE FROM THE HOUSE TO THE SHOP?
Yes. It is always good to use wire heavier then you require, for long runs, because resistance builds up accumulatively.
But if you need it or not depends on the actual number of amps you will be drawing from all the things in the out building at the same time, and the size of the breaker you will be attaching it to.
For example, if you were to going to run a heater and a power tool at the same time, on 12 gauge wire in the storage building, along with a couple of lights, on a 20 amp breaker, then I would suggest 10 gauge to the shed. But if you are only going to run lights and one tool at a time, from a 15 amp breaker, you could probably get away with 12 gauge.
Oct 09, 2010 | Craftsman Grinders
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
I have a 200 amp service panel i have a 100amp
Theres a few different ways to set up the secondary panel. The most efficient way, in my opinion, would be to set it up as a subsidiary. This is a really great way to allow power to be shut off for sections of a house instead of killing everything. This requires wiring it to the main panel on a breaker which will serve as the main for the 100amp subsidiary. Obviously this will require that a comparable breaker be installed in the main 200 amp panel to support the new subsidiary 100 amp panel.
Here's where it gets tricky and you really should either consult or contract a licensed technician. Because the amperage rating does not dictate the amount of power that is supplied to your house on the primary line you are essentially using the new box as a splitter. The danger in this is that just like any common electrical outlet, the more stuff you plug into it the more likely you are to overload the circuit and risk catastrophic failure, like a house burning to the ground or worse.
Knowing that your panel is side by side, you should be fine with #2 AWG, I would confirm electrical code before installing and ensure that grounds are diverted to the main panel to avoid the risk of running live current through the otherwise 'safe' ground.
If you are installing the panel to increase the amount of breakers it is probably safe to assume that there has been some previous work done that fills up the main panel. I would strongly encourage you to talk to an electrician about your needs and the changes in your house that require the additional breaker slots. There is a certain amount of artistry involved in 'designing' the house and you could probably accomplish the same end result with one panel and a more efficient wiring plan.
Mar 08, 2010 | Your One Source Homeline Load Center, 200...
AC Breaker trips and AC Fan turns slow.
Sounds like you have a bad capacitor for your squirrel cage fan , now as for the a/c unit sounds like you have a direct short in compressor to ground or leg to leg , check all wiring to make sure that it is not grounding out or melted together.
Jul 23, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a 220v 100 amp circuit breaker that feeds a sub-panel. The sub-panel has 3 circuits: a)60 amp Heater (unit 1 in house) b)60 amp A/C (unit 2 in house) c) 40 amp for pool equipment. The 100 amp...
your a/c uses the blower motor from the heater to distribute air check for loose wire connections that will raise amperage and also make sure you have the right size wire to each unit 40 amp should have 8 awg(copper) wire and 60 shouldbe 6 awg i think if the wire is to small=heat= higher amperage
Jul 14, 2009 | Heating & Cooling
General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V Logo
216 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
