Question about Haier HD656E Dehumidifier
My dehumidifier has never gotten any water in the bucket
  • Haier Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Oct 09, 2010
My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
I just purchased this humidifier. I set the humidity temperature to 40 and the fan is constantly running but there is no water filling into the bucket. Although the humidity temperature is set to 40 the...
Nicole, some of the packing material may have gotten into the drain tubing or hole and clogged it. Remove the water reservoir and look for a vinyl tube or drain hole in the cavity that the "bucket" came out of. If you can see anything blocking it, carefully remove it. I don't think at this point anything would have gotten any further down the drain tubing. Since this a brand new unit, consult your Owners Manual for directions on how to Troubleshoot this problem. If that fails, it's under warranty. Contact the manufacturer as directed in the Owners Manual.
Hope this helps to get your problem solved.
Mar 17, 2011 | Haier HDN655E Dehumidifier
The dehumidifier will not run. It has power to the control panel but the "bucket full" light is flashing RED. We have a hose hooked up to the unit to drain the water and we have check the bucket...
Generally, the buckets on these units can be a little finicky. Especially, if the bucket is not installed properly. In other words, if the bucket doesn't trip the safety switch, when it's out in place and the "bucket full" indicator will remain on and the unit will not run. I suspect the hose attached to the bucket may have gotten the bucket slightly out of place and it's not triggering the safety switch. Turn the unit off, and reinstall the bucket,. Then turn the unit back ON. Make sure there is a little slack in the hose from the unit to the where ever you're draining the water to. In other words, the hose should not be pulling on the bucket.
As I said, they can be a little finicky, so be patient reinstalling the bucket. As it may take several tries, before you get it right.
Hope this helps solve the problem.
Mar 10, 2011 | LG Dehumidifiers
Does dehuidifiers stop working as hard in the winter months then in the summer months. Because my water bucket has not fill up since gotten cold. I live is Alexandria Va and it is winter here.
Generally speaking there is more moisture in the air during the summer months. As the humidity goes down in the winter your dehumidifier will not collect as much water because there is less moisture in the air.
Dec 28, 2010 | Haier DM30EAL Dehumidifier
No water collecting in bucket.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 30, 2010 | Goldstar DH504EL Dehumidifier
Every thing works but no water gathers in the bucket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Nov 03, 2009 | DeLonghi DE400P Dehumidifier Dehumidifier
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
Suddenly stopped working
remove bucket, look under for the bucket overflow switch, try tugging it a bit, may have gotten stuck when you pulled out the bucket
Jul 24, 2009 | Goldstar DH304 Dehumidifier
Water bucket - proper seating
Try re-seating the bucket. I have found some LG models that if not seated all of the way will sometimes keep running and think the bucket is not full even when it is. On the models that I have seen do it the problem is usually the left side of the bucket not engaging all of the way. When you reseat the bucket, feel where the bucket meets the dehumidifier on each side and make sure they are even. If one feels like it is sticking out further than the other and you cannot push it in any more pull the bucket out and try and reseat it again until both sides are flush with the dehumidifier. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 10, 2008 | LG DH404E Dehumidifier
Haier HD656E Dehumidifier Logo
81 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
