How do I replace the belt? Heller CD55 Tumble dryer I have a new belt, have removed the back off the dryer but don't know how to attach belt to drum.
How do I replace the drum belt on my heller CD55
Posted on Jan 10, 2014
Im looking for a picture of a heller cd55 dryer with the back off it. Mine has a broken terminal and not sure where it goes its the 2 light blue wires.
The thermal cut out device on the left of the picture which I see only one wire going to, should have a second terminal on it. It is similar to the one on the right with the red and orange wires.
May 03, 2016 | Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
How to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Oct 12, 2008 | Candy CDC266 Dryer
I have a Heller CD55 clothes dryer, it turns on, draws in air (i think) but doesnt turn or dry my clothes
Sounds like a broken drum drive belt.. Ours does this about once every 6 months.. When it was in warranty the first few times we'd wait the 3 weeks for Heller to post the belt (and the second time, a replacement overheat-cutout sensor, as I was getting sick of having to open the back up and reset it) to the local service place.. Then I got sick of that, and we just take teh 15 min drive to our local appliance parts place, and pickup a 'CPD 7 RIB' (part no 0198300011) belt from a fairly new model simpson dryer, which has exactly the same belt..
I probably wouldn't suggest trying it if you're not a home handyman, as it means pulling the back off, and disconnecting a few wires and undoing a few mounting bolts to get the new belt around the drum, but it's only a 10 minute job if you know what you're doing..
If you want to take it to your local service place, just make sure they realise that they don't have to go to the hellar importer to get the replacement belt - a current model simpson belt fits fine :)
PS, they're 192cm long, 1cm wide, 7 'ribs'..
--DG
Jul 09, 2008 | Dryers
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Washing Machines Logo
272 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
