Question about Toro Garden
Engine works unevenly running up and down constantly unless I push throttle to max near choke mode. At max it will work steady until it get too hot and then will stop. Neeed to let it cool down before it restart. Cleaned filter and carburator, changed sparkplug, new gas line with clamps at both side, new buble priming.
    President:
  • Toro Master
  • 1,545 Answers
Make sure that you have connected the governor and throttle linkage up correctly. Sometimes when assembled wrong, you get symptoms like yours. Go here:
http://www.smallenginesuppliers.com/shop/html/governor_adjustment.html
and here: http://small-engines.com/bsgovernors.html
Please vote on this solution.
Posted on Sep 10, 2010
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
My generator Jetman gg7200e idles uneven it accelerates and decelerates all the time unless i keep the choke nearly closed
That kind of surging usually happens when you are running out of gas. Is the fuel tank full and is it getting enough fuel to the carb when it needs it?
Aug 12, 2014 | Electrical Supplies
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Volvo v40 2000nx reg 1.8 NON gdi engine constant high rpm can having no thermostat cause constant high rpm or can a briken lambda sensor cause high rpm cleaned all throttle body cleaned idle valve checked...
Yes, having no thermostat can cause the car to run fast as it will still be set in it's "warm up" mode and will be injecting a richer mixture of fuel/air into the cylinders. There may be an additional cold start injector that just works while the engine is cold. You will probably use more fuel like this. It's not a great idea to run with no thermostat anyway because you get uneven hot and cold spots around the engine which is bad for it. Cheers
Feb 06, 2012 | 2000 Volvo V40
Redmax ebz5100 blower stumbles/misfires periodically until engine is hot?
What happens if you play with the choke ? does it clear up or change, If it does then it's a fuel problem example : fuel filter, fuel line cracked,dirt in carb. If the choke does'nt make a difference then , try a new spark plug Good Luck, Let me know how you come out 2StrokeJim
Nov 27, 2011 | Redmax Ebz5100 Back Pack Power Blower...
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Briggs & stratton engine will not remain running
You have one of the infamous automatic choke Briggs carbs. These are supposed to close that butterfly that you describe, which is actually the choke until it is running, then it's supposed to keep it open. The problems is, if the diaphragm in the carburetor starts getting hard, or leaks, it'll kill the operation of the choke. They are known for their unreliablility to the point of where it's a shock to find one that actually works. You can fix it by replacing the diaphragm inside the carburetor, or by putting a spring on it that holds it open unless you manually choke it to start it.
Mar 29, 2010 | Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
260 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
