Question about Cooper Industries Weller Field Soldering Iron, Controlled Output
The temperatures on our Weller WD2 are locked. Don't know how to unlock it.
Wont heat enough to solder
Hello, does your solder iron --Weller- humming? Also, is the solder tips the right tips for you Weller woldering gun? Are the tips tightened on the end of the solder gun prongs?
Well, if it is humming there is internal short in the windings inside of the gun. Don't mess with. Recyle it by taking the copper, brass, aluminum, and other metal out. Now, if it is not humming.
Make sure you have right tips, make sure that the tip is tightened in the soldering gun prongs.
The working principal of these soldering guns is that they work on low voltage and very high current. The current is regulated to keep the tip from burning into. Just enough current to heat the tipe to a certain temperature.. It can shock you but there not enough voltage with current but it will hurt. and could burn you. Be careful and lots of luck...GB...stewbison
Aug 04, 2011 | Weller Standard Tip: 7200
Is the weller 8200 comparable to the "Old Weller
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Apr 23, 2011 | Weller Welding Tools
I have a couple of Weller d550 Solder guns and am in need of replacement light bulbs for either side of the tip. Do you have them or can you direct me to someone who does? I am on the west coast. Don
Howdy, here is a solid vendor of weller parts and accessories who has the bulbs you are looking for.
http://www.all-spec.com/search?f=r&x=25&i=2&keywords= 8200
I hope you find this handy:)
farmerbear at FixYa.com
Sep 07, 2010 | Weller 8200 Soldering Gun
How do i unlock nokia 6600 ,
OK enter wrong password for more then 5 times,it ll ask u to enter the puk number....now call your customer care and get the
puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted
Oct 31, 2009 | Cell Phones
Register
These Nokia Unlock Codes are Generated For Nokia 6600 (WD2) with IMEI: 352274010936073 (DCT 4) Locked to Provider Bharti Cellular Telecom Airtel in India and will only work with this phone!
#pw+044333560225745+1#
#pw+347596465517401+2#
#pw+088533105617347+3#
#pw+122164645023475+4#
#pw+087443405506755+5#
#pw+845801062300113+6#
#pw+218505532607016+7#
Jun 28, 2009 | Nokia 6600
Any one have software to cell phone !!!! tq
you need to have the original firmware reflash on the phone.
Feb 07, 2008 | Nokia 6600
UNLOCK CODE FOR BB5/WD2 SOFTWARE IN CELLPH
Go to urrl: www.entsperren.at there You can get Your Unlock-Code for Your Nokia for free!!!!
Jan 22, 2008 | Samsung SGH-U700 Cellular Phone
Cooper Industries Weller Field Soldering Iron, Controlled Output Logo
282 people viewed this question
Top Cooper Welding Tools Experts
Bill Boyd
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
