Question about Roller Derby Mens Spartan 9.9 InLine Skates
How do i loosen the second strap!? - Roller Derby Mens Spartan 9.9 InLine Skates
  • 4 Answers
You have to pull the metal tab back all the way. It will click and lay flat, but you have to keep it pressed down for it has a tendency to snap shut). There are two ratchet stop check levers (black plastic pieces on the side of the strap). The way they look it would seem that you would have to squeeze them together, toward the strap, but you have to push them down towards the boot. Remember to keep the metal tab depressed so it doesn't snap shut on you. Once you push both levers down and clear the bevels on the strap, you can pull the strap back out. Open and close the strap a few times to get the "new" out of it. With more use, you will be able to squeeze the levers together (like you couldn't do the first time) and depress the levers in one motion making the taking off of your skate a lot easier. Hope this helped.
Posted on Aug 27, 2011
How do I get off the flywheel that is split into on a Yamaha 2004 G22A golf cart
Removing a split flywheel is always fun. I'm not familiar with that vehicle, but I do have some general suggestions;
Find a stable point to rest a screwdriver or prybar on and put blade into the teeth to loosen bolts.
Wrap a strap loosely around the flywheel, then place a screwdriver or other metal object ( socket extension, prybar, Ratchet, etc.) through strap. Twist bar until strap is tight on flywheel, then wedge bar to loosen strap. If you have room, you could have someone hold the bar and strap still as you loosen bolts. An air impact tool should loosen bolts quickly, but you have to be sure that bar is secure so you don't get whacked by the force of the impact.
You could also immobilise the crank shaft by wedging a tool or bar into the belt on the pulley, which will keep the flywheel from turning as you work.
Hope this helps and best of luck!
Jul 25, 2014 | Cars & Trucks
How to loosen straps on snorkeling mask
http://www.youtube.com/watch?v=ZaktqZSPmts
Here is a quick 2-minute video that will explain how to loosen the straps on your snorkeling mask, and tell you many other useful facts about snorkel masks. If your mask is a different model, you can look at the related videos on YouTube and find one that has straps similar to yours.
Jul 05, 2012 | Vision Mares Pure Mask
Can't get the crank pulley loose. is it left our right threads. i am replacing the water pump.
TURN CRANKSHAFT BOLT COUNTERCLOCKWISE TO LOOSEN. YOU HAVE RIGHT HAND THREADS.ENGINE TURNING CLOCKWISE.YOU NEED A STRAP WRENCH HOLD CRANKSHAFT PULLEY WHILE LOOSEN IT.BUT YOU NEED A CRANKSHAFT DAMPER REMOVAL TOOL.OR HARMONIC BALANCER REMOVAL TOOL.YOU NEED STRAP WRENCH TO HOLD CRANKSHAFT PULLEY WHEN TIGHTEN IT.TORQUE CRANKSHAFT PULLEY BOLT 90 - 98 FT LBS. MAKE JOB EASIER.HAVE A HELPER HOLD STRAP WRENCH WHEN YOU LOOSEN OR TIGHTEN CRANKSHAFT PULLEY.
Sep 19, 2010 | 1995 Mercury Villager
How do you loosen the second strap of a men's roller derby spartan 9.9 skate?
Aug 16, 2010 | Roller Derby Mens Spartan 9.9 InLine...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to loosen strap of roller derby's spartan 9.9 rollerblade. I can open the first strap but can't undo the second strap. I can only make it tighter.
You have to pull the metal tab back all the way. It will click and lay flat, but you have to keep it pressed down for it has a tendency to snap shut. There are two ratchet stop check levers (black plastic pieces on the side of the strap). The way they look it would seem that you would have to squeeze them together, toward the strap, but you have to push them down towards the boot. Remember to keep the metal tab depressed so it doesn't snap shut on you. Once you push both levers down and clear the bevels on the strap, you can pull the strap back out. Open and close the strap a few times to get the "new" out of it. With more use, you will be able to squeeze the levers together (like you couldn't do the first time) and depress the levers in one motion making the taking off of your skate a lot easier. Hope this helped.
Apr 01, 2010 | Roller Derby Mens Spartan 9.9 InLine...
I cannot get the straps to tighten anymore.
Without the model/make it is hard to say what your exact problem is but normally the manufacture's site has links to the user guide. I do have three areas you may want to look over: First the sholder straps themselves sometimes have loops or labels attachted. Make sure these are not preventing the straps from moving through the slots. Second have you attachted the sholder straps to the splitter, a metal bar attachted to the adjustment strap, if it exists on your model. Have you attachted them correctly. Third see if the splitter is stuck on something in the back.
Mar 20, 2010 | Baby Gear
How do I loosen up the base strap. I can't get it
I finally got the release to slide up out of the connection and pop off. Nothing to it after that.
Jun 23, 2009 | Graco Snugride
Harness problem on Eddie Bauer Car Seat
loosen the harness by lifting up on the metal latch located under the flap on the front of the seat and pulling on the straps. This should loosed the straps for you.
Dec 26, 2008 | Eddie Bauer Deluxe 3-in-1 Convertible
The straps will not loosen or tighten
double check on the web site. not too long ago there was a safety recall issued about the harness straps. if not you can always look on the company's web site for instructions
here is the link for recalls
http://www.coscojuvenile.com/safety_notice/
here is the link for you to input your model # and get the instructions online
http://www.coscojuvenile.com/instructions/
Oct 29, 2007 | Eddie Bauer Deluxe High Back Booster...
Roller Derby Mens  Spartan 9.9 InLine Skates Logo
93 people viewed this question
Top Roller Derby Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Roller Derby Boating Expert? Answer questions, earn points and help others
