Question about Niles ZR-4630 2 Channels Receiver
My Niles ZR-4630 always turns on all zones, unless I hold the master key down for 3 seconds. This is exactly the opposite of what it is supposed to do.
2 Suggested Answers
otacon
  • 1944 Answers
SOURCE: Niles ZR-4630
Thanks for the update. Did you try power cycling the unit?
Posted on May 22, 2008
None of the scientific atlanta codes work to program remote. tried to find the code, still no luck. Any ideas?
To which device do you want setup codes with this remote control? Provide more details please. If you wish to get code list for Scientific Atlanta remote control, check this link.
Feb 23, 2013 | Niles Audio Niles R8L FG01446 8 Source...
Niles ZR-6
I had the same issue as Brian, the Niles ZR8630 stays in initializing mode. At first, the unit would not turn on, so opened it and replaced the fuse, power was restored. But now the unit continually stays in INIT mode.
any body has an answer/solution?
Jul 30, 2012 | Niles ZR-6
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
Niles audio zr-4630 powers on then shows error code e1
Power cycling?!?!? Are you serious?!?!? Do you work in tech support?? Power cycling , what a genius.
Feb 02, 2011 | Niles ZR-4630 2 Channels Receiver
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
Casio CE-4630
Hi.
I don't have an error list for the 4630, but you could try a flag clear first. this will not cause any data loss:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep holding it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF"
Press SUBTOTAL
Wait for print, then turn back to REG mode.
If that doesn't work, let me know.
Mark
Mar 23, 2009 | Casio Parts Cash Register PC Desktop
I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Mar 18, 2009 | Casio Parts Cash Register PC Desktop
How to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
Dec 16, 2008 | BMW 750 Cars & Trucks
Niles ZR-4630
May 22, 2008 | Niles ZR-4630 2 Channels Receiver
Niles ZR-4630 2 Channels Receiver Logo
37 people viewed this question
Top Niles Audio Players & Recorders Experts
 Grubhead
Grubhead
Joseph Hoffmann
Rob
Rob
Are you a Niles Audio Player and Recorder Expert? Answer questions, earn points and help others
