Question about Maytag MSD2756GES Side by Side Refrigerator
The symptoms: fan starts and so does buzzing. buzzes for about 5 seconds then stops, compressor does not start. 1 minute passes fan still running buzzes for 5 sec then stops compressor does not start another minute or min and half same thing then on next minute or so the compressor takes off no buzz. What gives?
  • Maytag Master
  • 43,501 Answers
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Sep 11, 2010
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
My maytag refrigerator started making a buzzing noise every time it goes on. it lasts about 5 seconds then clicks off. any idea what it is?
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Jul 21, 2009 | Maytag MSD2651 HE Side by Side...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Refridge and freezer stopped cooling
it is either the start switch on the side of the compressor or the compressor itself.
the buzzing sound is the start switch trying to start the compressor and the click is the overload on the start switch kicking it out.
the start switch is bad or the compressor is pulling too much amps = bad compressor.
Jun 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
117 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
