Question about Samsung Digimax S630 Digital Camera
I can't take pictures because of card error appears
  • kakima Sep 10, 2010
    What type and size memory card? The S630 works with MMC and SD cards. If your card is larger than 2GB then it's an SDHC card, not an SD card, and won't work in the S630.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume it was an SD/SDHC mismatch.
Posted on Oct 17, 2010
File error appears on screen when viewing pkotos
can have different causes. To many pictures on the memory card card is full. From the last picture file name ends with 999 or 9999.
Or there was an error while writing a picture to the memory card, caused by a power failure.
I would put the card in an external memory card reader and try to put all pictures in a folder on the computer. Then format the card FAT 32 or FAT 16 and then put it back in the camera. When switched on, first format the card again, in the camera, to make sure the camera can work with the card and the format.
Success.
Apr 19, 2015 | Cameras
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Unrecognizable file format
In your camera settings menu, there is probably an option for you to switch the different kinds of file formats that the pictures are saved onto your memory card as.
Your memory card might not support certain file types.
Apr 09, 2010 | Kodak EASYSHARE M1063 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Picture error
I would recheck all of my settings on the camera. Go to the menu and check everything one by one. Your card may be damaged also. Do you have another card to try? Do you have your manual? If not you can to to www.olympus.com to download a new manual specifically for your camera and it may address this issue. Good luck.
Aug 14, 2008 | Olympus SP-700 Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Memory card error
did you buy the camera new?
Mar 17, 2008 | Samsung Digimax S730 Digital Camera
Lens error message
If the pictures are on an SD card you can simply remove the card and use a card reader on your computer to copy the pictures off.
Stores will often also have picture printers that can read the SD card.
Mar 08, 2008 | Vivitar ViviCam 5385 Digital Camera
Error message to turn camera off and then on again
Have you tried taking the card out and removing the battery and trying again. I had an issue with one card - no different from the others I use Scandisk 2GB but problem has now gone.
Jan 29, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
