Question about Hoover Vacuums
How do you change idler pulley assembly on a hoover windtunnel can;t get to it
4 Suggested Answers
  • 126 Answers
SOURCE: Hoover Windtunnel not picking up as well
There is a height adjustment on these vacuums and they are set to adjust in the "handle up" position". It will appear that the adjustment is doing nothing when the handle is up, but the setting will take affect when the handle is lowered.
You can check the brush length with a pen or pencil. Turn the machine over so that the brush is visible and run the pen or pencil flat across the bottom plate. Any where the brush is extending outward, your pencil should contact the bristle. If not, then the agitator should be replaced.
Also, check to make sure that the agitator is rotating freely and that the filters and bag are allowing for adequate suction. The machine will only pick up if the air flow is sufficient.
Posted on Mar 23, 2008
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
I have a hoover windtunnel turbo power 8000 self propelled model u6660-900. I bought a agitator belt for it that says it's the correct one ( belt #38528-034) according to several websites. But for some...
The belt is correct. You idler pulley is most likely hung up. Look half way between the brushroll and the drive pulley ( that's what the belt wraps around ) there is an idler pulley that puts pressure on the backside of the belt. They are prone to hanging up. A qualified vacuum repair shop can take care of this for you if you can't figure it out.
Oct 20, 2013 | Vacuums
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover WindTunnel Self-Propelled V Belt
Hi, That is what was happening to my Windtunnel. Until I looked at the little round disk "plastic". there was a crack in it and this puts pressure onto that V belt to make the brush spin. I have a replacement idler arm assy unit which has to be replaced. I hope this helps Cindy G.
Aug 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover windtunnel
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Jan 18, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover Windtunnel
Your belt may be twisted inside-out. Be sure the printed marks on the belt face away from the pulleys and shaft. The printing should face you.
Oct 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
41 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
