Question about Fujitsu Siemens AMILO Xi 1546 Notebook
The computer runs for a few minutes than shuts down. it looks like the fan is not running. gets hot than shuts downs
    Guru:
  • 689 Answers
Basic solution would be to clean dust on fan just jumpstart it with a pencil end if this doesnt work replace the fan theyre not that expensive youre lucky your pc has a shutdown option before other parts are permenantly damaged,try lubricating the centre bearing of the fan also with a fine viscosity lubricant would be another option
Posted on Sep 10, 2010
My Dyson Bladeless Fan/Heater is displaying E7 after a few minutes of running and then shuts down? It is brand new (a couple of months old) and been run about 3 times.
Hi Michelle, it's Jack at Dyson.
If your AM05 Hot + Cool heater is displaying the E7 error code, the best course of action is to contact us directly for further assistance. To diagnose the cause of the issue we would need to understand more about how the heater is being used - we should also be able to suggest a suitable resolution.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Dec 08, 2014 | Dyson Air Multiplier 10" AM01 Bladeless...
Why does 2000 s40 volvo turbo runs hot and the fan stays on after shut off
fans are designed to run on after you shut engine down as engine temperature rise after switching off . running hot could be caused by the top hose having gone soft when you rev the engine the water pump sucks the hose flat stopping the coolant flow or the radiator is blocked and need flushing out
Sep 16, 2014 | 2000 Volvo S40
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Still over heating
leaking head gaskest
Jul 19, 2012 | 1993 Toyota Pickup
When i turn off the car the fan continues to run?
Many cars have this feature. The fan will run for a few minutes at a time until the coolant in the radiator drops below a certain temperature. Most vehicles with this feature will have a warning label on the radiator shroud indicating that the fan may start without warning when the engine or radiator is still hot. The only time you would need to be concerned would be if the fan continues to run without turning itself off, and causing the battery to be drained.
Feb 19, 2011 | 2003 Jaguar X-Type
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
Fan wont kick on
If you are talking about the condenser fan not running, that would cause the unit to shut down on high discharge pressure. Is the indoor fan running? Check the capacitor for the outdoor fan. Also make sure the outdoor fan has power to it. If it has power and the capacitor is good then the fan motor may be bad. If the nc in your name stands for NC then it is possible I could take a look at it as I am in NC. Let me know what you find.
Jul 03, 2010 | Dometic Rooftop RV Air Conditioner
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
Hi
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
Samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
Jan 12, 2009 | Samsung SMH7178STD Microwave Oven
The unit runs for a few minutes and completely shuts down
Without the model or make sound like a bad thermostat..check amps the the compressor and voltage... if the compressor is locking up or the thermostat cutting voltage to it..
Hope this helps
Apr 05, 2008 | Refrigerators
Fujitsu Siemens AMILO Xi 1546 Notebook Logo
254 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
