Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
My brand new hp 8500 wireless office ink jet printer say open the carriage access door clear the jam. We took the small 2 ink cartiages out and put them in again and this keeps come up.What do we do now? Please help. Thanks
    Genius:
  • 1,089 Answers
Why are you taking out the ink cartridges??
The message says to open the carriage access door and clear the jam. The printer thinks that paper is stuck in the paper path, see if you can find it. I believe that there is also a rear door on that printer, remove it and look inside.
Posted on Sep 11, 2010
I get broken gear in my hp officejet pro 8500a
Someone pulled hard on jammed paper to remove it from the printer. This has broken the small plastic paper advancing gear on the left-hand side of the printer (have seen this mistake a number of times). The printer is broken and cannot be fixed, and it is time to purchase a new one. What you and everyone needs to learn from this is to NEVER pull hard to remove paper out of your printer. Be careful, and open the access doors to get to it.
We would suggest that you upgrade to an HP 8600 series printer and if you print more than 500 pages per month you purchase an AdaptiveInk continuous ink supply system (CISS). Adaptive Ink Continuous Ink Supply System Home Page Adaptive Ink HP Pigment ERC
Mar 12, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Had paper jam, removed from back of machine, now display says Carriage Jam Open print carriage access door, clear jam and press ok. I have done this and still flashing up the same msg. There isnt...
If the printer thinks it has a Carriage jam, you might want to try removing the ink cartridges and then putting them back. It's possible they got bumped out of place during the paper jam. Hope you can figure it out!
Feb 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I keep getting a printer jam error for the hp officejet 8500 wireless, no paper jam, have done everything HP suggests and still won't work. Can anyone suggest what to do other than buy a new printer?
Hi
This is a coomon problem with the printer the best thing to do is call HP and advise them of the issue. I recently had a customer who did this and even know it was out of warranty they replaced the printer.
Thanks
Daniel
HP Technician
Nov 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Where is the printer carriage access door located?
Hi
The door shown in this picture is carriage access door
2386b83.gif Let us know if in case you need any more information
All the best!!
Regards
Nov 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Trying to start up HP office jet pro 8500 wireless and it says carriage jam "open the print carriage access door. clear the jam, and then press OK to continue" where is the print carriage access door? ...
The problem is a small gear that is locate in the back left part of the printer. The plastic clip that holds it in place breaks and the gear does not come all the way to the right thus causing an error.
This is not a easy fix. When this happened to me I replaced the complete insides of the printer. If this is a 8500 with the color screen it might be worth fixing but if it is the two line screen then I would just buy a replacement printer online.
If you remove the outer plastic pieces you should be able to see when the gear does not seat properly.
Michael
Perfect Printer Parts
perfectprinterparts@gmail.com
Oct 21, 2010 | Office Equipment & Supplies
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I do not know how to open the printer carriage access door to clear a paper jam
You can find detailed instructions on clearing paper jams, including carriage jams, here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3752462
Oct 29, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
486 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
