Question about Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556
Should I remove the cardboard panel under my Maytag fridge that is under some black coils held on by 6 white plastic caps?
2 Suggested Answers
philbran
  • 242 Answers
SOURCE: Maytag MZD2766GEB refrigerator does not
to get to the adc board and it is common for these to go out , you have to grab the plastic cover from the very back of the cover and pull towards the front of the unit , you should see the slots your sliding it off , somtimes it is a bear to slide off..
then after that there are phillips screws going into the roof of the unit , you just have to loosen these and slide the entire control section to the right to unlock from cabinet.
you should see the adc now and its a tight squeez to remove and replace , make sure there is no power to the unit.
Let me know if you have any questions.
Phil
Posted on Jun 10, 2009
My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Aug 05, 2012 | Maytag Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
There is a click sound and fridge fail to start
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 18, 2010 | GE GTH18JBR Top Freezer Refrigerator
My frost free refrigerator doest not cool. the bi-metal thermostate has been replaces 3 times and the timer once. what to do? my e-mail address is royanil@hotmail.com
If your fan is running inside the fzr and the fan under the bottom ck and make sure the coils are clean under the fridge. If all of the above are working and the coil is clean make sure the black cardboard piece is covering the back side this directs air from the front across the coils and exits by the fan. Then the only thing left is loss of freon in the system. Make sure the compressor is kicking in when you turn it on you will hear it hummm and it will be warm to the touch. If the compressor is not kicking in then I would suspect the starter relay under the plastic cap on the compressor its the size of a nickle and is connected to one of the 3 prongs coming out of the compressor. unplug you fridge before handling the elect parts. good luck
Aug 17, 2010 | GE 17.9 Cu. Ft. Frost-Free Top-Mount...
My maytag side by side psb2151grw fridge is not cold on the fridge side, but the freezer is working fine. fridge is set at 8 and freezer is set at 6. Sometimes there is frost in the freezer, I just scrape...
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Aug 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a maytag side by side with water/icemaker. model msd2456dew. it has frozen up in the freezer, under the white interior paneling. we think this is what is causing the cool air to not filter into...
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Jul 28, 2010 | Refrigerators
The dividing strip between the freezer & fridge is hot.
Pull the refrig out and remove the rear cardboard panel . Check to see if something is caught in the fan blade stopping it from turning . Also , make sure the black square coils are clean . If the fan is not turning , and no obstruction , replace the fan motor . Use a small house fan to cool the compressor until the motor is replaced or the compressor could stop working .
May 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
There is a black tape that seems to be unraveling from my maytag atlantis. This tape is under the top rim of the basket. Any Ideas of what this is and if it needs to be replaced. My machine is 8 years old
Looks like this is the white plastic shield gasket:
You need to remove the front panel, loosen the top panel to be able to remove the plastic shield (it's just clipped on).
Once you have the shield removed, put gasket back in place so you are back in washing business.
Good Luck!
Aug 17, 2009 | Maytag Washing Machines
Maytag fridge isn't cooling
I recommend that you do preventive maintenance by cleaning the cob webs and dust accumulation from the coil located on the bottom of the refridgerator. The coils can be seen from the front of the fridge at floor level behind the removable plastic grille cover. The coils need to be also cleaned at the back of the fridge located near floor level, usually covered by a black colored, cardboard material cover that is removable. First start your cleaning process with a vacuum and hose attachment and clean as much as possible of the large debris. Second. use compressed air along with the vacuum to blow out any debris that could not be reached in the first step. Turn thermostat settings for fridge and freezer back to normal settings and allow time for temperatures to reset.
Jun 26, 2009 | Refrigerators
Maytag Atlantis Model 6400AEW Dryer bought 2003
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Jan 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Refrigerators Logo
410 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
