Question about Hasselblad 500mm f/8 CF Tele-Apotessar T Lens
HASSELBLAD 500mm f/8 teleapostar,lens will not **** or stay cocked even with the tool.the small holding pin off to the side has apeared to fallen down inside the lens? what has to be done to repair this issue.Thank you
Toyo 500mm lens to nikon d90 mount
At the risk of being obvious, you need a Nikon mount.
The lens comes with a T-mount. This is a "universal" mount with adapters for almost any camera mount, including the Nikon F mount. If the lens doesn't come with one, get a Nikon T-mount adapter.
The lens doesn't have any electronics, so you'll be shooting completely manual. No autofocus, no autoexposure, not even any exposure help from the camera's light meter.
Feb 23, 2013 | Konica Minolta Minolta Telephoto Camera...
How to attach filters to a Rokinon 500mm/ 1000mm Mirror Lens for Canon EOS
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
Jan 15, 2011 | Rokinon 500mm f63 Mirror Lens for Nikon...
How to put filters in opteka mirror lens
ON THE BOTTOM SIDE THAT MOUNTS TO YOUR CAMERA THEY ARE VARY SMALL THE SIZE IS (M 30.5 )
Dec 15, 2010 | Opteka 500mm f/8 for Canon EOS
My Hossiblad 501cm won't accept my lens anymore. It worked fine up until recently. When I place the lens into the body it turns but does not lock in.
Maybe the lens and the body is "out of sync"?
Check the little slottet screw-like thing in the buttom of the lens. If the shutter in the lens has been released, this little screw needs turning until the shutter is cocked. The slot should be parallel to the edge of the lens.
May 17, 2010 | Hasselblad 501CM Medium Format Camera
Using a 500mm fixed aperture lens on a Pentax ist
Use "exposure compensation" (the button with a plus/minus symbol). It allows you to lighten (toward the + side) or darken (toward the - side).
Nov 15, 2009 | Pentax *ist DL Digital Camera
HOW TO SET UP CAMERA WITH 500MM LENS
Hey SHUTTER HEAD,
Without knowing what camera you have I would set your camera's aperture to f/8. I would have your camera mode set to either aperture priority or manual, and leave the aperture on the camera set to f/8.
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Quantaray 500mm f/8.0 Mirror with Macro...
Hasselblad 500mm f/8 CF Tele-Apotessar T Lens Logo
44 people viewed this question
Top Hasselblad Cameras Experts
Michael Galve
Michael Galve
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
